Custom Weighing Solutions for Horticulture
Aranet provides a portfolio of wireless weighing solutions for horticulture, from standard configurations to custom builds. All solutions are designed for greenhouse use and integrate into the Aranet ecosystem for centralized monitoring and alerts.
Typical applications
Propagation trays and potted plants
Slab and gutter systems for substrate cultivation
Strawberry containers and pot-based setups Recess for the container: 965 x 150 mm (L x W) for the pictured setup.
Crates and specialty containers Suitable for crates measuring 667 x 445 x 195/85 mm (L x W x H); other sizes available on request.
Weight solution for tree nurseries
Cradle weight for flower growers
Weighing is one of the most direct ways to understand plant water use and irrigation performance. By tracking weight changes over time, growers can see evaporation and uptake patterns, compare zones, and make irrigation adjustments based on reliable, representative measurements.
Key benefits
  • Representative measurements by weighing multiple plants or an entire tray, not just a single plant
  • Consistency and leveling to keep measurements reliable and comparable
  • Mobility friendly for operations using moving tables or mobile growing systems
  • Scalable approach that balances data quality and cost, without needing a sensor on every plant
Custom solutions
If your crop setup does not match standard trays, containers, gutters, or slab sizes, we can adapt an existing weighing solution or engineer a bespoke design to fit your exact greenhouse application.
  • Adjusting the dimensions of an existing weighing solution includes a defined customization fee and one revision round
  • Bespoke engineering is available based on an hourly engineering rate.
How it works
A
Weight data from the Voshol frame is sent by Aranet wireless sensor to the Aranet base station.
B
Base station data is accessed from Aranet Cloud software locally or remotely.
C
Gain insights into the seedling weight changes and patterns from dashboards in Aranet Cloud. Set email or SMS alarms for timely reaction.
D
Optimize growth process and seedling irrigation, resulting in saved water and better root system.
