> For the complete documentation index, see [llms.txt](https://help.aranet.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://help.aranet.com/pro-series-sensors/pro-series-sensors/weight-sensor.md).
# Weight Sensor
Continuous weight measurement using the Aranet Weight sensor enables real-time monitoring&#x20;of various plant growth factors, including biomass increase, plant weight, water addition, and&#x20;drainage weight. Both the 50 kg and 100 kg versions operate wirelessly and are powered by a&#x20;single AA battery. For more comprehensive insights, consider combining multiple weight&#x20;sensors to detail processes within the greenhouse.
#### Use cases
Measurements allow us to foresee problems, which can result in a slowdown in production and&#x20;plant overload. Weight sensors can also be used to gain insights about fruit weight, evaluate&#x20;average fruit growing days, and assess leaf weight on the plant. Data enables the analysis of&#x20;biomass distribution by examining weight changes at fruit and leaf harvest, as well as tracking&#x20;weekly yield and other parameters.
Combine multiple weight sensors and track weight for several parameters to obtain more&#x20;detailed information about processes in the greenhouse. The Aranet Cloud platform allows the&#x20;creation of virtual sensors to calculate the difference or sums between the measurements.
It is possible to use a weight sensor for a specific, custom weighing solution, more available here: [Custom Weighing Solutions for Horticulture](/pro-series-sensors/pro-series-sensors/weight-sensor/custom-weighing-solutions-for-horticulture.md)
#### Good practice recommendations
To track biomass gain, fruit load, etc., install a Weight sensor directly at the truss.
<div data-with-frame="true"><figure><img src="/files/Ah6nSOgckhsESlcndqCu" alt=""><figcaption></figcaption></figure></div>
{% columns %}
{% column %}
In case several weight sensors are used for\
more precise plant growth insights, feel free&#x20;to create a frame with several weight&#x20;sensors, as well as install the weight sensors&#x20;for the whole plant section as a reference&#x20;section for a greenhouse.
{% endcolumn %}
{% column %}
<div data-with-frame="true"><figure><img src="/files/29lmNwC61BZsbNWQ3WnA" alt=""><figcaption></figcaption></figure></div>
{% endcolumn %}
{% endcolumns %}
{% columns %}
{% column %}
<div data-with-frame="true"><figure><img src="/files/lMg8e7UMdIbbqVoYCQ2L" alt="" width="175"><figcaption></figcaption></figure></div>
{% endcolumn %}
{% column %}
<div data-with-frame="true"><figure><img src="/files/3jDQMyyGI2PVgGswZ7os" alt="" width="174"><figcaption></figcaption></figure></div>
{% endcolumn %}
{% column %}
The large water content in plants and fruits is&#x20;the primary factor contributing to the&#x20;weakening of the radio signal if sensors or the&#x20;base station are positioned too low. The sensor&#x20;has an extended wire to a transmitter - position&#x20;the transmitter (white body approximately one&#x20;foot or 30 centimeters above the expected&#x20;maximum height of the plants.
{% endcolumn %}
{% endcolumns %}
#### Specific notes
{% tabs %}
{% tab title="Using Web GUI" %}
To reset the zero offset of weight (tare), click on the TARE button. The last measured tared and (untarred&#x20;weight), as well as the date and time of the last tare event, will be indicated.
<div data-with-frame="true"><figure><img src="/files/XsLoremM7VO8k7wUbKiD" alt=""><figcaption></figcaption></figure></div>
By default, the graph of the Weight Sensor will display&#x20;measurements of a tared weight. To display the untarred&#x20;weight in the graph, click the Tune button and&#x20;tick the “Show” box.
<div data-with-frame="true"><figure><img src="/files/CD3SCCVpk0kyREci0ouC" alt="" width="130"><figcaption></figcaption></figure></div>
{% endtab %}
{% tab title="Using Aranet Cloud" %}
To tare the weight measurement, go to the base station management feature in the Aranet Cloud&#x20;interface. Click on “Add & Manage Sensors,” select your weight sensor, and then click on the&#x20;TARE button.
<div data-with-frame="true"><figure><img src="/files/qoi36KUeEIqMAaZjpUVM" alt=""><figcaption></figcaption></figure></div>
<div data-with-frame="true"><figure><img src="/files/MZGb2ATwyMlC8hdQXbAg" alt=""><figcaption></figcaption></figure></div>
<div data-with-frame="true"><figure><img src="/files/p9YLbxXlyxZygQy6GX8s" alt=""><figcaption></figcaption></figure></div>
<div data-with-frame="true"><figure><img src="/files/0qNP527GOTrXkbOpwr09" alt=""><figcaption></figcaption></figure></div>
{% endtab %}
{% endtabs %}
GET https://help.aranet.com/pro-series-sensors/pro-series-sensors/weight-sensor.md?ask=<question>&goal=<endgoal>
