Base Station's Web GUI Configuration
The soil (substrate) VWC, EC, and T Sensor displays the Volumetric Water Content and Pore Water Electrical Conductivity measurements values (Temperature is displayed on the graph).
Under the “Sensors” menu it is possible to select the calibration of the VWC and EC (pore water) calculation method, by selecting Topp G.C., Mineral Soil, Rockwool Ecover, or Rockwool Grodan.
VWC is defined as 6th order polynomial of Epsilon:
VWC = a+b*ε+c*ε2+d*ε3+e*ε4+f*ε5+g*ε6
Where ε is the apparent dielectric permittivity calculated from RAW by
ε = (2.887e-09 * RAW3 – 2.080e-05 * RAW2 + 5.276e-02 * RAW – 43.39)2 .
Presets based on calibration results
1
Grodan
GT Master
2021 May
4.00 (0.02)
22 (2)
H10 x 15 x 17 cm
2x, inserted horizontally, 4 cm from bottom of slab
2
Grodan
Prestige
2021 May
4.00 (0.02)
22 (2)
H7.5 x 17 x 15 cm
3
Ekover
Grunt Tomato
2021 May
4.00 (0.02)
22 (2)
H7 x 20 x 14.5 cm
4
Ekover
Grunt Green 1.0
2021 May
4.00 (0.02)
22 (2)
H7.5x17x20 cm
5
Ekover
Grunt Green 2.0
2021 May
4.00 (0.02)
22 (2)
H7.5x17x20 cm
6
Ozo Golf Club
2021 May
0.25
22 (2)
NA
2x
7
Grodan
DM 32 40/40 HUGO
2021 October
2.1
NA
H14.5x14.5x13.75 cm
2x, inserted horizontally, 7 cm from bottom of slab
8
Charcoir
3 Liter BioPot
2022 April
1.3
NA
16x16x16 cm
2x, inserted horizontally, 1.25 inches from bottom of slab
9
Kekkila
Natural Control
2022 July
4.5
NA
24x12x19 cm
Coefficient values used in presets
1
Topp G.C. et al. (1980)
0
0
0
4.300e-06
-5.500e-04
2.920e-02
-5.300e-02
doi:10.1029/WR016i00 3p00574
2
mineral soil
0
0
-2.925e-08
7.293e-06
-6.845e-04
3.129e-02
-3.612e-02
recommendation by MeterGroup; 0-8 dS/m, 0-60% VWC
3
rockwool Ekover
0
2.070e-09
-5.405e-07
5.443e-05
-2.649e-03
6.858e-02
-4.324e-02
T=22 °C; EC=4 dS/m; Tomato/Green 1.0/Green 2.0; 4 cm from bottom
4
rockwool Grodan
0
0
-7.785e-08
1.756e-05
-1.395e-03
5.224e-02
-5.440e-02
T=22 °C; Prestige/GT Master/DM32 40/40 HUGO
5
coco or peat
0
0
0
0
0
6.276e-03
2.420e-01
30-60% VWC; Charcoir/Kekkila
6
soiless media
-1.655e-10
4.353e-08
-4.473e-06
2.261e-04
-5.812e-03
7.991e-02
-6.141e-02
custom
0
0
0
0
0
0
0
write calibration conditions here
If any of the preset calibration values are changed, the method type will be changed to “Custom”.
The graph of soil sensors by default displays Temperature, Volumetric Water Content, and Pore Electrical Conductivity. The thresholds can be set in the sensor’s interface
Use the Tune button (in the Graph section), to display the Bulk Electrical Conductivity and dielectric permittivity (ε).
It is possible to order sensor calibration coefficients for your substrate in SAF Tehnika. Please contact support@aranet.com for details.
