Operational Range and Radio Frequencies
The Aranet system uses frequencies from the ISM radio band. The frequency allocation for this band depends on the region, so Aranet has 5 versions of each product that cover most of the world:
EU868:
  • Channel 1: 868.10 MHz
  • Channel 2: 868.30 MHz
  • Channel 3: 868.50 MHz
The Aranet system can operate up to 3 km / 1.9 mi in the line-of-sight (LoS) range. Line-of-sight range means that there are no visible obstacles that are in-between the base station and the sensor, e.g. an open field, a large hall.
