Skip to content
Device Security
For enhanced security, Aranet uses a proprietary LPWAN protocol.
Aranet systems use the XXTEA encryption when the data is transmitted from the sensors to the base station. A unique encryption key is provided for each base station. The transmission protocol has built-in safeguards against malicious operations (for example, replay attacks).
Aranet sensors are protected from unauthorized data collection; even if sensors are accessed, the software used and the configuration parameters cannot be compromised.
To connect new sensors, the user needs to be in proximity to the base station; it is not possible to connect new sensors without authorization in order to compromise the Aranet system by obtaining the encryption key.
