> For the complete documentation index, see [llms.txt](https://help.aranet.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://help.aranet.com/base-stations/base-stations/base-station-configuration/local-ip-network-setup/remote-access-via-wi-fi-network.md).
# Remote Access via Wi-Fi Network
{% hint style="warning" %}
Keep a spare Ethernet cable nearby. Use it if the Wi-Fi setup fails. Ethernet access lets you fix the network settings.
Use this guide to connect an Aranet Pro/Pro Plus base station to local Wi-Fi. After setup, open the WebGUI from the same Wi-Fi network.
{% stepper %}
{% step %}
### Collect your Wi-Fi (and optional IP) details
You will need:
* Wi-Fi network name (SSID)
* Security/encryption type (for example, WPA2-PSK)
* Wi-Fi password
If you must use a static IP address, also prepare:
* IP address (unused)
* Subnet mask
* Default gateway
* DNS server
<details>
<summary>Windows 10/11 (GUI): find SSID, security type, and IP settings</summary>
Go to **Start > Settings** and open **Network & Internet**.
<div data-with-frame="true"><figure><img src="/files/GO0lmv5yhQ86PiNdc32T" alt="" width="563"><figcaption></figcaption></figure></div>
At **Network status**, click **Change adapter options**.
<div data-with-frame="true"><figure><img src="/files/abqeikN183fV6kNkWEaO" alt="" width="563"><figcaption></figcaption></figure></div>
Double-click the active **Wi-Fi** connection.
<div data-with-frame="true"><figure><img src="/files/3iY3SfWPqmgzSstXxd2x" alt="" width="551"><figcaption></figcaption></figure></div>
Click **Details** and note:
* IPv4 Address
* Subnet Mask
* Default Gateway
* DNS Servers
<div data-with-frame="true"><figure><img src="/files/TerpLH8jlMbFSfs48FJD" alt="" width="353"><figcaption></figcaption></figure></div>
<div data-with-frame="true"><figure><img src="/files/ZYrQyuS59GEaJmoe24ge" alt="" width="370"><figcaption></figcaption></figure></div>
Click **Wireless Properties**.
<div data-with-frame="true"><figure><img src="/files/6snNcDmk5AGV4KOGiPDb" alt="" width="353"><figcaption></figcaption></figure></div>
On **Connection**, note the SSID.
<div data-with-frame="true"><figure><img src="/files/ghaC7l6A9Jn185Uv9V6R" alt="" width="392"><figcaption></figcaption></figure></div>
On **Security**, tick **Show characters** and note:
* Security type
* Encryption type
* Network security key (password)
<div data-with-frame="true"><figure><img src="/files/ubFo9YhSWIsmfHaKxKdp" alt="" width="392"><figcaption></figcaption></figure></div>
</details>
<details>
<summary>Windows (Command Prompt): find IP settings and check a free static IP</summary>
Open Command Prompt and run:
* `ipconfig /all` (note IPv4 address, subnet mask, default gateway, DNS servers)
<div data-with-frame="true"><figure><img src="/files/Iw1ih9mDQKj4s7by2Bh5" alt="" width="514"><figcaption></figcaption></figure></div>
Check the Wi-Fi authentication type and SSID:
* `netsh wlan show interfaces`
<div data-with-frame="true"><figure><img src="/files/AZzKLTnkhwj6Fv7RYaEJ" alt="" width="511"><figcaption></figcaption></figure></div>
If you plan to use a static IP, pick an unused address. Validate it with `ping`. Start with the same subnet. Change only the last octet.
Example: if your PC is `192.168.43.228`, test `192.168.43.229`.
<div data-with-frame="true"><figure><img src="/files/iyD7hjxn4iCC1eTZprDg" alt="" width="395"><figcaption></figcaption></figure></div>
If you get replies, the IP is already in use:
<div data-with-frame="true"><figure><img src="/files/FMXxZebSAFfTyrzdSpMK" alt="" width="563"><figcaption></figcaption></figure></div>
If you see **Destination host unreachable**, the address is likely unused:
<div data-with-frame="true"><figure><img src="/files/oNEz6ZaZTYyKhlfxUGqq" alt="" width="563"><figcaption></figcaption></figure></div>
</details>
{% endstep %}
{% step %}
### Connect to the base station Wi-Fi access point
1. Disconnect your PC from the local Wi-Fi network.
2. Connect to the base station’s built-in Wi-Fi access point (SSID = base station name).
3. Open a browser and go to `http://192.168.206.100`.
   {% endstep %}
{% step %}
### Configure Wi-Fi client mode in WebGUI
1. Open **SYSTEM > NETWORK** and select the **WIFI** tab.
2. Set **Mode** to **Client**.
3. Set **Country** and **Power** (leave defaults if unsure).
4. Select (or enter) your local Wi-Fi **SSID**.
5. Select the matching **Encryption/Security** type.
6. Enter the Wi-Fi password.
7. Choose IP assignment:
   * **DHCP** (recommended for most networks)
   * **Static IP** (only if required by your network policy)
   If you use **Static IP**, fill in IP address, subnet mask, default gateway, and DNS server.
8. Click **Save**.
After saving, your connection to the base station access point will drop.
<div data-with-frame="true"><figure><img src="/files/KK6XBNA2L9f2BNMrmLjz" alt=""><figcaption></figcaption></figure></div>
{% endstep %}
{% step %}
### Reconnect and log in to the base station
1. Connect your PC back to the local Wi-Fi network.
2. Open the base station WebGUI:
   * If you configured a **static IP**, use that address.
   * If you used **DHCP**, check your router’s DHCP lease list. Or ask your network admin.
Example (static IP): `http://192.168.43.229`
<div data-with-frame="true"><figure><img src="/files/FmOvfeX60BuIKtGdxSRp" alt=""><figcaption></figcaption></figure></div>
{% endstep %}
{% endstepper %}
### Remote access from the Internet
Internet access requires a **public static IP address** and **port forwarding** on your router. Ethernet is the preferred interface for remote access.
See [Remote Access via Ethernet Network](/base-stations/base-stations/base-station-configuration/local-ip-network-setup/remote-access-via-ethernet-network.md) for the overview and an example URL format (`xx.xx.xx.xx:port`).
GET https://help.aranet.com/base-stations/base-stations/base-station-configuration/local-ip-network-setup/remote-access-via-wi-fi-network.md?ask=<question>&goal=<endgoal>
