Remote Access via Ethernet Network
Use this guide to access an Aranet Pro/Pro Plus base station WebGUI from the Internet.
Ethernet is the preferred interface for remote access.
Prerequisites
You need:
  • A public static IP address on your router.
  • Admin access to the router.
  • A stable internal IP address for the base station:
    • Static IP on the base station, or
    • a DHCP reservation on the router.
Configure Ethernet under SYSTEM > NETWORK > ETHERNET.
See Network.
1
Verify local access over Ethernet
  1. Connect the base station to your router or switch via Ethernet.
  2. Confirm you can open WebGUI from the local network.
  3. Note the base station Ethernet IP address.
2
Create a port forwarding rule on the router
Create a NAT/port-forward rule that maps an external port on the router to the base station.
Typical mapping:
  • WAN (external) port: 8100 (example)
  • LAN (internal) IP: base station Ethernet IP (example: 192.168.1.50)
  • LAN (internal) port: 80 (WebGUI)
  • Protocol: TCP
Router interfaces differ by vendor.
Check your router manual for the exact UI.
Example:
3
Test access from outside your local network
From an external network (for example, mobile data), open:
<public-ip>:<external-port>
Example:
213.100.100.1:8100
Some routers do not support “NAT loopback”.
In that case, the external URL may not work from inside the same LAN.
Test from outside your network.
