Connecting the Base Station to the Network
Use this page to connect an Aranet Pro/Pro Plus base station to your network. Use Ethernet when possible. It is the most reliable option.
You configure all interfaces under SYSTEM > NETWORK. See Network for field definitions and factory defaults.
The Globe symbol with no crossover (green) indicates a working Internet connection.
Ethernet (recommended)
If your network has a DHCP server, the base station will usually be online right away. Ask your network admin if you are unsure.
Connect the Ethernet cable
Aranet Pro Plus
Connect the base station to a PoE injector OUT port. You can use TDAPOE03. You can also connect it to a PoE-enabled switch. Wait until the Ethernet LED is on.
Aranet Pro
Connect the LAN port to your router or switch. Check that the LAN LED is on.
Wi-Fi (client mode)
Use Wi-Fi when Ethernet is not available. You can configure Wi-Fi while connected to the base station Wi-Fi access point.
If you lose access during setup, reconnect to the base station access point. Then open http://192.168.206.100.
Select the network and enter credentials
Under Select from this list or input manually, choose your Wi-Fi SSID.
Choose the required Encryption/Security type.
Enter the Wi-Fi password.
Note the Wi-Fi interface MAC address (useful for DHCP reservations).
Choose IP assignment:
DHCP (recommended)
Static IP (advanced)
Click Save.
Most Wi-Fi routers have DHCP enabled by default. Keep DHCP unless you have a strong reason to use Static IP.
Reconnect and find the new IP address
After you click Save, the page may reload. If you were connected to the base station access point, the connection will drop.
Connect your PC to the same Wi-Fi network you selected.
Wait until the base station finishes connecting (watch the Wi-Fi LED activity).
Find the IP address assigned by DHCP:
Check your router’s DHCP lease list.
Or ask your network admin.
Or scan the subnet with a network scanner.
Scanner examples:
Windows: Advanced IP Scanner
macOS: LanScan
Typical workflow:
Scan the same subnet your PC is connected to.
Locate the base station by the MAC address you noted earlier.
Use the shown IP address to open the WebGUI.
LTE (Aranet Pro Plus LTE only)
The LTE menu appears only when the modem is detected. Insert a mini-size GSM SIM card with a mobile data plan. The SIM card is not included.
Mobile data may create extra costs. Those costs are not covered by Aranet.
If you bought the Aranet Cloud Connectivity Service (P/N TDLCLCS0100G or TDLCLCS010RG), contact support@aranet.com. Provide the SIM EID, base station S/N, and the country of use.
Verify the connection
Wait for the settings to take effect. A page reload may be required.
A successful connection is indicated by:
an IP address assigned to LTE
the Globe symbol with no crossover
This screen also shows the modem status.
For remote access over LTE, request a static IP address from your mobile provider.
Static-IP LTE setup may differ from dynamic LTE setup. Check the required parameters with your mobile provider.
Before removing the SIM card, clear the LTE fields. Disable LTE and click Save. Otherwise, the SIM card may get blocked.
