Local IP / Network Setup
Additional features like network time synchronization (NTP), reporting and alarm notifications using e-mail, connection to Aranet Cloud, etc., require connectivity to the Internet (or internal data (Local) network). Connection to Local Area Network (LAN) and Internet using Ethernet cable is preferable, connection using Wi-Fi and LTE is also possible.
Default network settings, which are factory set:
Ethernet:
  • DHCP client
  • Static IP fallback - ON
  • IP address - 192.168.205.100
  • Subnet mask - 255.255.255.0
Wi-Fi:
  • Enabled
  • Access Point option set
  • SSID - Name of the Aranet base
  • IP address - 192.168.206.100
LTE (only Aranet Pro Plus LTE base station):
  • Disabled
  • APN - onomondo
Connect the base station to the network using a PoE injector
Plug in an Ethernet cable connected to the powered PoE-enabled switch or powered PoE insert TDAPOE03 "OUT" terminal; plug in another Ethernet cable to PoE insert "IN" terminal and connect it to the LAN Ethernet switch (router).
For the Aranet Pro Plus base station, wait until the LED indicators "Power", "System", and "Ethernet" turn on.
For the Aranet Pro base station, wait until the LED indicators "12V" and "LAN" turn on.
