Diagnostic Files
When the DIAGNOSTICS button is pressed then a file is generated that contains log information about what happened on the Aranet base station after the last base station restart. The file can only be read by the Aranet R&D department and can’t be opened and read by the user. When the Aranet base station is restarted or completely loses its power, then the diagnostics info is also cleared. If Aranet support asks you to downlaod the diagnostic file, you can do it here:
Or through the cloud-based management if your firmware on the base station is v4.9.9 or newer:
