Deleting User Data
Use Factory Reset to restore the Base Station to factory defaults.
Factory Reset is irreversible.
It deletes all user settings. You will lose any previous configuration or setup.
Please access WebGUI and head to the SYSTEM -> TOOLS page.
Log in to WebGUI of the Base Station with root or administrator credentials
Go to the TOOLS page in the SYSTEM
Click on the FULL FACTORY RESET button
The factory reset starts after you click on the button.
Use Factory Reset when:
The device needs to be completely cleared before transfer
There is a requirement to remove all data, including private and sensitive information
When performing a Factory Reset:
All user-defined settings are erased
Network configuration is restored to default (DHCP)
The base station is disconnected from the previously configured Aranet Cloud environment
The device returns to its initial state as during first-time setup
When the device is operating normally
When there is no such need
