Connecting to Aranet Cloud
Before proceeding, please make sure that the prerequisites have been met: Prerequisites for Base Station Registration
Aranet base can be connected to Aranet Cloud by registering it to the Workspace. The Aranet Cloud Workspace creation process is described in this topic: Create Workspace
If you just created a new Workspace, go to Base stations and press ADD BASE STATION button:
If you want to register a new Aranet base to the existing WORKSPACE,
  • Log in with your credentials to Aranet Cloud and select WORKSPACE you wish to add a new Aranet Pro base to (you should have Administrator or Owner rights).
  • Navigate to the Base stations tab.
  • Click on the NEW BASE STATION button.
  • Choose device type "Aranet Pro"
There are two ways to connect a base station to Cloud.
  1. The Cloud to Base way or remote registration (Only from Base station FW 4.5.0)
  2. The Base to Cloud way
1. The Cloud to Base way or remote registration.
To register the base station remotely, you first have to go to the Cloud workspace you want to add the base station to and click on the Base stations tab. After, you can click on the NEW BASE STATION BUTTON and a new screen will pop out:
From here, you have to enter the base's serial number and the default WiFi SSID.
  • If you have the Pro+ line of base stations (white), it will have a sticker on the front, behind the glass of the info.
  • If you have the regular Pro model (black) base station, the sticker with the serial number is on the back. But the WiFi SSID is only visible if the base station is plugged in and you have a device that can see WiFi signals. You should use the default Wi-Fi SSID, if it is changed, it will not work.
!NOTE! The base has to be at least FW 4.5.0
Afterwards, the base station will show up as pending and can take up to 2 hours after it has an internet connection to connect to the Cloud.
If you are not able to register using this method, you can click on REGISTER USING BASE STATION UI.
2. Base to Cloud registration
Aranet base must be connected to Internet!
Further, follow the instructions in new pop-up window:
When registration code is created on the Aranet Cloud system side, then the next user must log in to Aranet Pro base station WEB graphical user interface, go to the Aranet Cloud section, and here enter in the appropriate fields the same e-mail and registration code as prompted in Aranet Cloud message. Then the user must click the button REGISTER TO THE CLOUD:
After successful registration and sensor data upload to the Aranet Cloud workspace, the Aranet base station itself will show the following information in Aranet Cloud section:
Aranet base will start its’ paired sensor measurement data upload to the Aranet Cloud platform. The sensor data upload process, depending on sensor data and data connection speeds between the Aranet Pro base station and Aranet Cloud system, can take up to 20 – 30 minutes. During this process, sensor data will gradually appear in the Aranet Cloud workspace.
