> For the complete documentation index, see [llms.txt](https://help.aranet.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://help.aranet.com/base-stations/base-stations/base-overview/pro-base-station.md).
# Pro Base Station
#### Contents of the box
* Aranet Pro base station with installed Aranet SensorHUB software and License.
* Aranet Pro base station mount.
* 2 pieces of W1412 screws for mounting the base station.
* AC power adapter (EU or US version, depending on product version).
#### Indicators of the base station
<div data-with-frame="true"><figure><img src="/files/MQM9pBIEYaCbIJDkgB8D" alt=""><figcaption></figcaption></figure></div>
1. **Sensor data indicator LED** – flashes amber every time a data packet is received from a sensor.
2. **Wi-Fi connection indicator LED** – amber light when Aranet PRO is connected to Wi-Fi or works in   \
   Access Point mode.
3. **LAN connection indicator LED** – amber light when Aranet PRO is connected to LAN interface using an   &#x20;Ethernet cable.
4. **12V power indicator LED** – green light when Aranet PRO is connected to 12V power either through a   &#x20;PoE connection or with the included AC power adapter.
5. **Battery power indicator LED** – red light when Aranet PRO is using built-in backup battery power.
#### Base station mounting
<div data-with-frame="true"><figure><img src="/files/JAWbyElvwMhbqQdIyheN" alt=""><figcaption></figcaption></figure></div>
1. Base station mount configuration for positioning on a vertical surface.
2. Base station mount configuration for positioning on a vertical surface.
3. Base station mount configuration for placement on a horizontal surface.
{% hint style="warning" %}
Make sure to NOT install the base station in a faraday cage structure. A Metal enclosure made of conductive material of any kind would count as this. This will significantly reduce the range of the base station.
#### Base station ports
<div data-with-frame="true"><figure><img src="/files/GTfC4TzsNrvt7KnkIc6n" alt=""><figcaption></figcaption></figure></div>
1. On-Off switch – switch in the left position means the Pro base station is turned off, switch in the right position   &#x20;means Aranet Pro is turned on.
2. AC Power port - for using the included AC power adapter to power Aranet Pro.
3. Ethernet port – for LAN connectivity as well as PoE connectivity.
4. Reset button –– press and hold for 5 seconds or more, and then release the button to reset the network   &#x20;settings and password of the “root” user account. The reset button is accessed through the hole with a   &#x20;thin object, like a pencil.
5. USB port – for connecting a USB modem to enable SMS notification functionality.
GET https://help.aranet.com/base-stations/base-stations/base-overview/pro-base-station.md?ask=<question>&goal=<endgoal>
