Pro Base Station
DIscontinued
Contents of the box
Aranet Pro base station with installed Aranet SensorHUB software and License.
Aranet Pro base station mount.
2 pieces of W1412 screws for mounting the base station.
AC power adapter (EU or US version, depending on product version).
Indicators of the base station
Sensor data indicator LED – flashes amber every time a data packet is received from a sensor.
Wi-Fi connection indicator LED – amber light when Aranet PRO is connected to Wi-Fi or works in Access Point mode.
LAN connection indicator LED – amber light when Aranet PRO is connected to LAN interface using an Ethernet cable.
12V power indicator LED – green light when Aranet PRO is connected to 12V power either through a PoE connection or with the included AC power adapter.
Battery power indicator LED – red light when Aranet PRO is using built-in backup battery power.
Base station mounting
Base station mount configuration for positioning on a vertical surface.
Base station mount configuration for placement on a horizontal surface.
Make sure to NOT install the base station in a faraday cage structure. A Metal enclosure made of conductive material of any kind would count as this. This will significantly reduce the range of the base station.
Base station ports
On-Off switch – switch in the left position means the Pro base station is turned off, switch in the right position means Aranet Pro is turned on.
AC Power port - for using the included AC power adapter to power Aranet Pro.
Ethernet port – for LAN connectivity as well as PoE connectivity.
Reset button –– press and hold for 5 seconds or more, and then release the button to reset the network settings and password of the “root” user account. The reset button is accessed through the hole with a thin object, like a pencil.
USB port – for connecting a USB modem to enable SMS notification functionality.
