Base Station and Gateway Comparison
Comparing Aranet Base Stations and Aranet Gateways helps users understand their differences in functionality, integration support, and licensing. This enables informed decision-making and helps select the solution that best fits specific monitoring and operational needs.
For a general overview of the differences between the two devices, you can also refer to this overview document. But for a more detailed in-depth comparison, see the table below.
N/A – Not Applicable: This functionality is not supported by the device and is not planned for future implementation.
TBI – To Be Included: This functionality is not currently supported by the device but is planned for implementation in a future firmware releases.
General
Protection grade
IP67
IP20
Coverage
3 km / 1.9 mi line fo sight
Sensor Qty
Default
12
100
Paid License 12-50
Yes
N/A
Paid License 12-100
Yes
N/A
Paid License 50-100
Yes
N/A
Virtual Sensors
Weight Sum
Yes
N/A
Sensor Name
Yes
Yes
Sensor Group
Yes
N/A
Measurement thresholds
Yes
TBI
Measurements history
Yes
N/A
System
Device Name, edit
Yes
Yes
Region: Language
EN, LV, RU, FR, DE, ES, IT, ND, PT
EN
Region: Selectable First Day of the Week
Mon, Sun
N/A
Region: Temperature scale
C, F, K
C, F, K
Region: pressure unit
hPa, mmHg, inHg, bar, psi, atm
Region: Diff. pressure unit
Pa, mbar, mmH2O
Pa, mbar, mmH2O
Region: Weight unit
kg, lb
kg, lb
Region: Distance unit
mm, mil, cm, in, m, ft
Region: Radon unit
Bq/m3, pCi/L
Bq/m3, pCi/L
Region: Time fomat
12H, 24H
12H, 24H
Region: Date format
YYYY/MM/DD, DD/MM/YYYY, MM-DD-YYYY, YYYY-MM-DD, DD-MM-YYYY
YYYYMMDD, DDMMYYYY, MMDDYYYY, YYYYMMDD
Region: Dateformat - separator
N/A
Time: Editable NTP servers list
Yes
N/A
Time: default NTP servers
0.pool.ntp.org, 1.pool.ntp.org, 2.pool.ntp.org
N/A
Time: Zone, selectable
N/A
Yes
Wi-Fi: AP
Yes
N/A
Wi-Fi: Client
Yes
Yes
Wi-Fi: Encryption
None, WPA-PSK, WPA2-PSK
None, WEP,WPA, WPA/WPA2, WPA2, WPA2/WPA3, WPA3
Ethernet:
DHCP, Static
DHCP, Static
Ethernet: Static IP fallback
Yes
N/A
LTE
TDSBOBx3
N/A
Firmware: Check for update
Yes
Yes
Firmware: Offline manual install
Yes
N/A
Backup: local download/upload
Yes
TBI
Backup: content
chanscan, favorites, Hwsettings, metadata, Modbus-autogen-layout, pacnum, sensors, users, workey
N/A
Backup: export/import/upload to Cloud
Yes
TBI
Tools: Reboot
SW, power
Power
Tools: Network reset
Yes
N/A
Tools: Factory reset
Yes
Yes
Tools: Diagnostics
Locally downloadable/uploadable to Cloud file
Crash report to Cloud
Paid Integrations Licenses
Yes
Yes
Notifications: sensor alarms
Yes
TBI
Notifications: SMS
TDSBOBx3
N/A
Notifications: e-mails
Yes
N/A
Radio: channel select
Yes
N/A
Radio: channel scan
Yes
N/A
Users:
Admins, Users
TBI: PIN lock
SNMP
Yes
N/A
Aranet Cloud
Debug logs
Yes
TBI
MQTT
License
File
Virtual
Host Address
Yes
Yes
Port
Yes
Yes
Protocol: v3.1
N/A
Yes
Protocol: v3.1.1
Yes
Yes
Protocol: V5
Yes
Yes
Keep alive
Yes
Yes
Authentification: Usename/Password
Yes
Yes
QoS level: 0
Yes
Yes
QoS level: 1
Yes
Yes
QoS level: 2
Yes
Yes
Editable Root topic
Yes
Yes
Sensor measurement format: raw
Yes
Yes
Sensor measurement format: json
Yes
Yes
Sensor measurement format: Azure IoT Hub
Yes
TBI
Transport protocol: TCP (mqtt)
Yes
Yes
Transport protocol: TCP+TLS (mqtts)
Yes
Yes
Transport protocol: Websocket (ws)
N/A
Yes
Transport protocol: Secure websocket (wss)
N/A
Yes
Encryption version: TLS v1.1
Yes
auto
Encryption version: TLS v1.2
Yes
auto
Encryption version: TLS v1.3
Yes
auto
LWT Retain
Yes
Yes
Validate Host certificate
Yes
Yes
Modbus TCP/IP
License
File
Virtual
Port
Yes
Yes
UnitID
Yes
Yes
Default Register Layout download
Yes
Yes
Regenerate Default Register Layout
Yes
Yes
Custom layout file upload/download
Yes
N/A
BACnet IP
License
File
TBI
Eth interface only
Yes
Port
Yes
DeviceID
Yes
Network Number
Yes
Location
Yes
Allowed IP list
Yes
Sensor measurement object type: Analog Input
Yes
Sensor measurement object type: Analog Value
Yes
InfluxDB (standard)
License
File
TBI
Ping interval
Yes
Server address
Yes
Port
Yes
SSL
Yes
Yes
Host CA certificate upload
Yes
Organization
Yes
Bucket
Yes
Token
Yes
Help
Support contact details
N/A
Yes
