> For the complete documentation index, see [llms.txt](https://help.aranet.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://help.aranet.com/aranet4/aranet4-home/usage-and-measurements/use-in-high-altitude-areas.md).
# Use in High Altitude Areas
The CO₂ sensor of the device is calibrated at standard atmospheric pressure.&#x20;
{% hint style="warning" %}
It is not intended to use the device higher than 4000 m (13 000 ft) above sea level.
If the device has to be used at high altitude, [manual calibration](/aranet4/aranet4-home/usage-and-measurements/calibration-and-errors.md) of the unit should be performed.
GET https://help.aranet.com/aranet4/aranet4-home/usage-and-measurements/use-in-high-altitude-areas.md?ask=<question>&goal=<user_goal>
