> For the complete documentation index, see [llms.txt](https://help.aranet.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://help.aranet.com/aranet4/aranet4-home/quick-start-guide.md). Agents can also search and read this documentation through its [MCP server](https://help.aranet.com/~gitbook/mcp).
# Quick Start Guide
Get started with your Aranet4 HOME sensor: display, setup, configuration switches and pairing with the Aranet Home app.
{% hint style="info" %}
🌐 Also available in: [Nederlands](https://help.aranet.com/aranet4/nl/aranet4-home/quick-start-guide) · [Français](https://help.aranet.com/aranet4/fr/aranet4-home/quick-start-guide) · [Deutsch](https://help.aranet.com/aranet4/de/aranet4-home/quick-start-guide)
<figure><picture><source srcset="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2FDa02cbXPBnpW98zhBeeV%2Faranet4-hero-world-dark-c.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2FIsKxzeEWmgH0X0z8IXt0%2Faranet4-hero-world-c.png?alt=media" alt="Aranet4 HOME – Quick Start Guide" width="768"></picture><figcaption></figcaption></figure>
### What does Aranet4 monitor?
CO₂ is colorless and odorless, so you can't tell when it builds up indoors. In rooms with poor ventilation, CO₂ levels rise quickly as people breathe, which can lead to tiredness, headaches and reduced concentration. Monitoring CO₂ shows you when it's time to open a window or improve ventilation.
The Aranet4 HOME sensor measures CO₂, temperature, relative humidity and atmospheric pressure. Its NDIR sensor ensures accurate CO₂ measurements. The E-Ink display and long battery life make it ideal for continuous indoor air quality monitoring.
#### CO₂ levels
CO₂ is expressed in parts per million (ppm).
{% columns %}
{% column %}
<figure><img src="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2F3oAmnf5Ke6RXU5KZec03%2Faranet4-co2-level-green-world-b.png?alt=media" alt="Aranet4 screen with a green CO₂ level" width="100%"><figcaption></figcaption></figure>
#### <img src="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2FxrEgNnU34AQMoxpO34Kc%2Flevel-dot-green.svg?alt=media" alt="" data-size="line"> Green
#### Below 1000 ppm
Optimal CO₂ level indoors.
{% endcolumn %}
{% column %}
<figure><img src="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2FmJ32L3RXQNqy4YVqZe3g%2Faranet4-co2-level-yellow-world-b.png?alt=media" alt="Aranet4 screen with a yellow CO₂ level" width="100%"><figcaption></figcaption></figure>
#### <img src="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2FpLRXjHBCck68lStTIxUv%2Flevel-dot-yellow.svg?alt=media" alt="" data-size="line"> Yellow
#### 1000 to 1400 ppm
Brain cognitive function decreases by 15 %.
{% endcolumn %}
{% column %}
<figure><img src="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2FgeeXUU1PxyHFHATJ3Boq%2Faranet4-co2-level-red-world-b.png?alt=media" alt="Aranet4 screen with a red CO₂ level" width="100%"><figcaption></figcaption></figure>
#### <img src="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2FDy8kvCCeHnZ4ELunp3ns%2Flevel-dot-red.svg?alt=media" alt="" data-size="line"> Red
#### Over 1400 ppm
Brain cognitive function decreases by 50 %.
{% endcolumn %}
{% endcolumns %}
These are the default thresholds. You can change them in the Aranet Home app.
A dot on the threshold indicator means that you have set your own threshold in the Aranet Home app.
{% hint style="success" %}
420 ppm – fresh outdoor air.
#### Temperature
The optimal indoor temperature ranges from 18 to 24 °C / 64 to 75 °F.
#### Relative humidity
The ideal relative humidity is between 30–50 % indoors. Low humidity (< 30 %) can cause skin to get dry and irritable. Environments that are too humid (> 50 %) cause bacteria and mold to breed.
### Display
<figure><picture><source srcset="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2FPSLNCekhS2B0bdxeC0Gb%2Faranet4-display-world-dark-a.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2FLdJxIfGsYVARGRiewIJW%2Faranet4-display-world-a.png?alt=media" alt="Aranet4 display with numbered callouts" width="640"></picture><figcaption></figcaption></figure>
1. Temperature (°C, °F)
2. Automatic calibration
3. Battery level
4. Adjustable CO₂ thresholds
5. Device number
6. Relative humidity (%)
7. CO₂ concentration
8. Buzzer status
9. CO₂ threshold indication
### Setting up the device
Pop in the batteries and your Aranet4 is ready to go.
{% hint style="warning" %}
#### Caution
* The Aranet4 is not impact resistant.
* Do not leave an Aranet4 in direct sunlight.
* Do not expose an Aranet4 to high-humidity environments (> 85 %).
### Configuration switches
The switches can be found behind the battery. Use the attached pin to adjust these settings:
<figure><picture><source srcset="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2FQTJwJpSuamLywchqxrSb%2Faranet4-config-switches-dark-v3-sw1.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2F6YiHTVm9QIR5BeS5Xy5w%2Faranet4-config-switches-light-v3-sw1.png?alt=media" alt="Aranet4 configuration switches with numbered callouts" width="640"></picture><figcaption></figcaption></figure>
1. Change the CO₂ calibration mode (AUTO / MANUAL)
2. Change the temperature units (°C / °F)
3. Turn Bluetooth on or off (connection to the Aranet Home app)
4. Connection to Aranet base stations (only for Aranet4 PRO)
Removing the batteries erases the measurement history stored on the device. Sync the data in the Aranet Home app first. You can change the switches with the batteries inside.
Your Aranet4 has been calibrated at the factory, so there is no need to change the calibration mode now. For more information, see the [user manual](https://help.aranet.com/aranet4/aranet4-home/usage-and-measurements/calibration-and-errors).
Download the Aranet Home app and connect your smartphone to your Aranet4 to:
* access measurement data
* store up to 90-day measurement history
* adjust CO₂ thresholds and set the buzzer
* change the sensor measurement frequency and much more
* track atmospheric pressure
For more technical information, see the [Aranet4 sensor data sheet](https://aranet.com/downloads/aranet4-home-datasheet).
### Aranet Home app
Download the Aranet Home app from the App Store or Google Play. You can scan the QR code with your phone camera or go to [aranet.com/aranet-home-app](https://aranet.com/aranet-home-app).
Each sensor also has its Quick Start Guide inside the Aranet Home app.
<figure><picture><source srcset="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2FQvcOCelJiV8jEAEqmZ1N%2Faranet4-home-app-world-dark-a.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2FJr8skIBdyD6aRdOXNahe%2Faranet4-home-app-world-a.png?alt=media" alt="Aranet Home app with QR code" width="640"></picture><figcaption></figcaption></figure>
<p align="center"><a href="https://apps.apple.com/us/app/aranet4/id1392378465"><picture><source srcset="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2FsSwL7Hxr8xqqBYg9zOO8%2FApp_Store-Dark.svg?alt=media&amp;token=2ff107bc-81e7-43f1-97e7-be9df4795f25" media="(prefers-color-scheme: dark)"><img src="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2FVll57HuYqvjAULp2Qzgt%2FApp_Store-Light.svg?alt=media&amp;token=8a745dd9-97cf-4783-89b7-b935eeccb9b1" alt="Download on the App Store"></picture></a> <a href="https://play.google.com/store/apps/details?id=com.saf.aranetCube.android"><picture><source srcset="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2F1iYoLFG3LrvXMcwSNUkh%2FGoogle_Play-Dark.svg?alt=media&amp;token=153a5c4b-84d8-4fbd-a3a2-909182680182" media="(prefers-color-scheme: dark)"><img src="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2FEXDg93iRaVsQ44fej5YO%2FGoogle_Play-Light.svg?alt=media&amp;token=7a8727f2-285a-4841-b089-2a2f8b13d4bd" alt="Get it on Google Play"></picture></a></p>
### Pairing the sensor with the Aranet Home app
{% stepper %}
{% step %}
#### Tap “Add Sensor”
Open the app and tap the **Add Sensor** button in the top-right corner.
<figure><picture><source srcset="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2FnBb2DXWhA4IElUiKWccM%2Faranet4-pairing-step1-dark-a.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2FYRupdzrR3icDBpINgaJD%2Faranet4-pairing-step1-a.png?alt=media" alt="Add Sensor button in the Aranet Home app" width="640"></picture><figcaption></figcaption></figure>
{% endstep %}
{% step %}
#### Find your sensor
The app will automatically search for nearby sensors. Once your sensor appears in the list, tap the blue **“Pair +”** button. The device number is shown on the sensor screen.
<figure><picture><source srcset="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2F4q7lA14rXqOJLFnz58fy%2Faranet4-pairing-step2-dark-a.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2F9dUuIJjEnQNmf6sa2LBo%2Faranet4-pairing-step2-a.png?alt=media" alt="Finding the sensor in the list of nearby sensors" width="640"></picture><figcaption></figcaption></figure>
{% endstep %}
{% step %}
#### Pair your sensor
A Bluetooth pairing request will appear. Enter the pairing code displayed on your sensor to complete the pairing process.
<figure><picture><source srcset="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2FfKDqa66FRrzBNWs3b9on%2Faranet4-pairing-step3-dark-a.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2FijR5Eg5NmZB5oOQDVQNm%2Faranet4-pairing-step3-a.png?alt=media" alt="Bluetooth pairing request" width="640"></picture><figcaption></figcaption></figure>
{% endstep %}
{% step %}
#### Start using your sensor
Once paired, your sensor is ready to use. A new sensor tile will automatically appear on your dashboard.
<figure><picture><source srcset="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2FaVdFPjyMR3axuovPLq4V%2Faranet4-pairing-step4-world-dark-a.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2FpBisX4h81AhJgn5q2wgR%2Faranet4-pairing-step4-world-a.png?alt=media" alt="New sensor tile on the Aranet Home dashboard" width="640"></picture><figcaption></figcaption></figure>
{% endstep %}
{% endstepper %}
### Adjust measurement intervals
{% stepper %}
{% step %}
#### Open device settings
Open the Aranet Home app and go to **Device Settings**.
<figure><picture><source srcset="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2Fgs2ovTFFpgpFjic7j8wl%2Faranet4-interval-step1-world-dark-b.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2FfdBEPgqYnx8wIB7bvdqs%2Faranet4-interval-step1-world-b.png?alt=media" alt="Device settings in the Aranet Home app" width="640"></picture><figcaption></figcaption></figure>
{% endstep %}
{% step %}
#### Choose the interval
Under **Measurement interval**, choose how often the sensor should take measurements.
<figure><picture><source srcset="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2FWydTwlXGvmMS9fpkMLTp%2Faranet4-interval-step2-dark-b.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2FNbdaYV0E9QO9TWBCWCCu%2Faranet4-interval-step2-b.png?alt=media" alt="Measurement interval options" width="640"></picture><figcaption></figcaption></figure>
{% endstep %}
{% endstepper %}
Select the option that best fits your needs. Shorter intervals provide more frequent updates, while longer intervals help extend battery life.
### More information
For more about Aranet4 HOME, including measurements, settings, firmware, maintenance and FAQ, visit the [Aranet4 HOME help page](https://help.aranet.com/aranet4/aranet4-home.md).
Copyright © SAF Tehnika, JSC. All rights reserved.
App Store and the Apple logo are trademarks of Apple Inc., registered in the U.S. and other countries. Google Play and the Google Play logo are trademarks of Google LLC.
GET https://help.aranet.com/aranet4/aranet4-home/quick-start-guide.md?ask=<question>&goal=<user_goal>
