> For the complete documentation index, see [llms.txt](https://help.aranet.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://help.aranet.com/aranet4/aranet4-home/manuals-and-firmware/firmware-update-issues.md). Agents can also search and read this documentation through its [MCP server](https://help.aranet.com/~gitbook/mcp).
# Firmware Update Issues
Sometimes the update might get "stuck" or not complete. Here is what you can do to troubleshoot the issue and find a solution.
{% hint style="warning" %}
This only works from the Aranet Home app v3.4.2. As such, you should update your app before trying this.
Removing the batteries erases the measurement history stored on the device. If the sensor is still connected, open the Aranet Home app and let it sync first, so the history is kept in the app.
{% columns %}
{% column valign="middle" %}
* Remove the batteries from the device and leave the sensor for 5+ minutes.
* Delete the sensor from both the Bluetooth device and app device lists.
* Re-add your sensor back in the Aranet Home app
* Retry the update process.
  {% endcolumn %}
{% column %}
<div data-with-frame="true"><figure><img src="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2F7lp47BRaZW8CyMjHBmYE%2FWhatsApp%20Image%202026-10-01%20at%2012.02.38.jpeg?alt=media&amp;token=a1de71a0-0075-4c48-8b83-056cf8f1a5a9" alt="" width="188"><figcaption></figcaption></figure></div>
{% endcolumn %}
{% endcolumns %}
There is a possibility that the device is still waiting for the update to begin, but the phone is not sending anything to the sensor. In such cases, please restart your phone, then open the Aranet Home app and go back to the *Firmware Update* option. The update should continue from the point where it was stopped.
GET https://help.aranet.com/aranet4/aranet4-home/manuals-and-firmware/firmware-update-issues.md?ask=<question>&goal=<user_goal>
