> For the complete documentation index, see [llms.txt](https://help.aranet.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://help.aranet.com/aranet4/aranet4-home/manuals-and-firmware/updating-firmware.md).
# Updating Firmware
Starting with Aranet Home app version v2.0, a firmware update can be done as follows:
{% columns %}
{% column valign="middle" %}
Locate the sensor you need to perform the update on. Then click on the three-dot icon and find *Device Settings.*
Scroll down and find the *Firmware Update* option and press it.
In the next window, if there is an update, you will be able to perform one. If not, then a message *Up to date* will be displayed.
{% endcolumn %}
{% column %}
<div data-with-frame="true"><figure><img src="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2FhAKzmMCb56oWGaO2DO1y%2FWhatsApp%20Video%202026-10-14%20at%2014.03.13.gif?alt=media&amp;token=2d4b0afc-76a8-4d4b-88d5-afef7c4fc697" alt="" width="135"><figcaption></figcaption></figure></div>
{% endcolumn %}
{% endcolumns %}
{% hint style="info" %}
Sometimes there might be an issue where the sensor is stuck during some operation, for example, a firmware upgrade.
If you are stuck in the update process, it is advised to open the Aranet Home app and try to add a new sensor. In most cases, this sensor will be discovered, paired back to the app, and working again. If the issue still persists, please contact <support@aranet.com> or refer to the information in another topic: [Firmware Update Issues](https://help.aranet.com/aranet4/aranet4-home/manuals-and-firmware/firmware-update-issues.md)
GET https://help.aranet.com/aranet4/aranet4-home/manuals-and-firmware/updating-firmware.md?ask=<question>&goal=<user_goal>
