Skip to content
Default Settings
The Aranet2 is calibrated in the factory, and it works instantly when you take it out of the box and insert the batteries – no additional setup is needed. These are the default settings of the Aranet2 device:
  1. The default measurement interval is set to 5 minutes;
  2. The default temperature measurement units are set to Celsius;
  3. Bluetooth connection is enabled;
  4. Bluetooth connection transmission range is set to normal;
  5. The buzzer for audio sound alarm notifications is disabled;
The 2nd and 3rd settings can be changed with the switches in the battery compartment on the back of the device for the Aranet2 screen, but the remaining three settings can only be changed via the Aranet Home phone application.
To change a switch, open the battery compartment and move the switch up or down with the pin tool supplied with the device. You can do this with the batteries inside. If you change the switches with the batteries removed, the new settings start working once the batteries are back in.
