> For the complete documentation index, see [llms.txt](https://help.aranet.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://help.aranet.com/aranet2/aranet2-home/quick-start-guide.md). Agents can also search and read this documentation through its [MCP server](https://help.aranet.com/~gitbook/mcp).
# Quick Start Guide
Get started with your Aranet2 HOME sensor: display, setup, configuration switches and pairing with the Aranet Home app.
{% hint style="info" %}
🌐 Also available in: [Nederlands](https://help.aranet.com/aranet2/nl/aranet2-home/quick-start-guide) · [Français](https://help.aranet.com/aranet2/fr/aranet2-home/quick-start-guide) · [Deutsch](https://help.aranet.com/aranet2/de/aranet2-home/quick-start-guide)
<figure><picture><source srcset="https://1419788306-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FWkQjwPV9Yi8oex9gapPt%2Fuploads%2Frdfl9DwMt4ldDsw4JT21%2Faranet2-hero-dark-a.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://1419788306-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FWkQjwPV9Yi8oex9gapPt%2Fuploads%2Fjc90S0QrmEYRpolR6020%2Faranet2-hero-light-a.png?alt=media" alt="Aranet2 HOME – Quick Start Guide" width="100%"></picture><figcaption></figcaption></figure>
### What does Aranet2 monitor?
Temperature and relative humidity have a direct impact on comfort and health. Air that is too dry can irritate skin, eyes and airways, while air that is too humid encourages mold and bacteria. Regular monitoring helps you keep your home in the healthy range.
The Aranet2 HOME sensor measures temperature and relative humidity. The E-Ink display and long battery life make it ideal for continuous indoor climate monitoring.
#### Temperature
The temperature measurement range is 0 to 50 °C (32 to 122 °F).
{% columns %}
{% column %}
<figure><img src="https://1419788306-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FWkQjwPV9Yi8oex9gapPt%2Fuploads%2FXS69GgXz5CRS9mqLdSG9%2Faranet2-temp-low-world-b.png?alt=media" alt="Aranet2 screen: temperature too low" width="100%"><figcaption></figcaption></figure>
#### <img src="https://1419788306-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FWkQjwPV9Yi8oex9gapPt%2Fuploads%2F932dHjAmFun4CpQSlHht%2Flevel-dot-blue.svg?alt=media" alt="" data-size="line"> Too low
#### Below 20 °C / 68 °F
Too cold for comfort indoors.
{% endcolumn %}
{% column %}
<figure><img src="https://1419788306-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FWkQjwPV9Yi8oex9gapPt%2Fuploads%2F3MeZyANMC7KNuzDqpdq5%2Faranet2-temp-good-world-b.png?alt=media" alt="Aranet2 screen: temperature good" width="100%"><figcaption></figcaption></figure>
#### <img src="https://1419788306-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FWkQjwPV9Yi8oex9gapPt%2Fuploads%2F3G7uqFmS1Nfz3sU400dT%2Flevel-dot-green.svg?alt=media" alt="" data-size="line"> Good
#### 20 to 25 °C / 68 to 77 °F
Comfortable indoor temperature.
{% endcolumn %}
{% column %}
<figure><img src="https://1419788306-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FWkQjwPV9Yi8oex9gapPt%2Fuploads%2FAdfLq3xXTmI2CmZJ6D2L%2Faranet2-temp-high-world-b.png?alt=media" alt="Aranet2 screen: temperature too high" width="100%"><figcaption></figcaption></figure>
#### <img src="https://1419788306-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FWkQjwPV9Yi8oex9gapPt%2Fuploads%2FDr84UvztoZ9GQZBVSgcQ%2Flevel-dot-red.svg?alt=media" alt="" data-size="line"> Too high
#### Above 25 °C / 77 °F
Too warm for comfort indoors.
{% endcolumn %}
{% endcolumns %}
#### Relative humidity
The relative humidity measurement range is 0 to 99 %. Relative humidity below 30 % can cause dry skin and irritation. Levels above 60 % can promote bacteria and mold growth.
{% columns %}
{% column %}
<figure><img src="https://1419788306-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FWkQjwPV9Yi8oex9gapPt%2Fuploads%2FEGrBlwId8WJUAo0dAWZb%2Faranet2-hum-low-world-b.png?alt=media" alt="Aranet2 screen: humidity too low" width="100%"><figcaption></figcaption></figure>
#### Below 30 %
Too dry: skin can get dry and irritated.
{% endcolumn %}
{% column %}
<figure><img src="https://1419788306-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FWkQjwPV9Yi8oex9gapPt%2Fuploads%2FModMJnVHiEIeWjHJ1qfM%2Faranet2-hum-good-world-b.png?alt=media" alt="Aranet2 screen: humidity good" width="100%"><figcaption></figcaption></figure>
#### 30 to 60 %
Comfortable indoor humidity.
{% endcolumn %}
{% column %}
<figure><img src="https://1419788306-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FWkQjwPV9Yi8oex9gapPt%2Fuploads%2FIUDbYqFmLFjgIWIO2wAz%2Faranet2-hum-high-world-b.png?alt=media" alt="Aranet2 screen: humidity too high" width="100%"><figcaption></figcaption></figure>
#### Above 60 %
Too humid: bacteria and mold can grow.
{% endcolumn %}
{% endcolumns %}
These are the default thresholds. You can change them in the Aranet Home app.
A dot on the threshold indicator means that you have set your own threshold in the Aranet Home app.
### Display
<figure><picture><source srcset="https://1419788306-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FWkQjwPV9Yi8oex9gapPt%2Fuploads%2Fy9QWS58XRykyJpNZVkNP%2Faranet2-display-dark-a-simple.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://1419788306-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FWkQjwPV9Yi8oex9gapPt%2Fuploads%2FeWW5Yt6URsnPjejH2B0K%2Faranet2-display-light-a-simple.png?alt=media" alt="Aranet2 display with numbered callouts" width="640"></picture><figcaption></figcaption></figure>
1. Relative humidity (%)
2. Battery level
3. Temperature (°C, °F)
4. Device number
### Setting up the device
Pop in the batteries and your Aranet2 is ready to go.
{% hint style="warning" %}
#### Caution
* The Aranet2 is not impact resistant.
* Do not leave an Aranet2 in direct sunlight or in freezing temperatures.
### Configuration switches
The switches can be found behind the battery. Use the attached pin to adjust these settings:
<figure><picture><source srcset="https://1419788306-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FWkQjwPV9Yi8oex9gapPt%2Fuploads%2FXs76b3yiOtm4P2v5cgnv%2Faranet2-config-switches-dark-v3-sw1.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://1419788306-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FWkQjwPV9Yi8oex9gapPt%2Fuploads%2FNwcBZqfqkeJzPhKZsbhA%2Faranet2-config-switches-light-v3-sw1.png?alt=media" alt="Aranet2 configuration switches with numbered callouts" width="640"></picture><figcaption></figcaption></figure>
1. Not used
2. Change the temperature units (°C / °F)
3. Turn Bluetooth on or off (connection to the Aranet Home app)
4. Connection to Aranet base stations (only for Aranet2 PRO)
Removing the batteries erases the measurement history stored on the device. Sync the data in the Aranet Home app first. You can change the switches with the batteries inside.
Download the Aranet Home app and connect your smartphone to your Aranet2 to:
* access measurement data
* store and export up to 90 days of data
* change the sensor measurement frequency and much more
For more technical information, see the [Aranet2 sensor data sheet](https://aranet.com/downloads/aranet2-home-datasheet). For more information, see the [user manual](https://aranet.com/downloads/aranet2-home-user-manual).
### Aranet Home app
Download the Aranet Home app from the App Store or Google Play. You can scan the QR code with your phone camera or go to [aranet.com/aranet-home-app](https://aranet.com/aranet-home-app).
Each sensor also has its Quick Start Guide inside the Aranet Home app.
<figure><picture><source srcset="https://1419788306-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FWkQjwPV9Yi8oex9gapPt%2Fuploads%2F1nPN69rSrCwlLNttoLff%2Faranet2-app-dark-a.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://1419788306-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FWkQjwPV9Yi8oex9gapPt%2Fuploads%2FzQdLd4DzH0clYzoGnWcX%2Faranet2-app-light-a.png?alt=media" alt="Aranet Home app with QR code" width="640"></picture><figcaption></figcaption></figure>
<p align="center"><a href="https://apps.apple.com/us/app/aranet4/id1392378465"><picture><source srcset="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2FsSwL7Hxr8xqqBYg9zOO8%2FApp_Store-Dark.svg?alt=media&#x26;token=2ff107bc-81e7-43f1-97e7-be9df4795f25" media="(prefers-color-scheme: dark)"><img src="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2FVll57HuYqvjAULp2Qzgt%2FApp_Store-Light.svg?alt=media&#x26;token=8a745dd9-97cf-4783-89b7-b935eeccb9b1" alt="Download on the App Store"></picture></a> <a href="https://play.google.com/store/apps/details?id=com.saf.aranetCube.android"><picture><source srcset="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2F1iYoLFG3LrvXMcwSNUkh%2FGoogle_Play-Dark.svg?alt=media&#x26;token=153a5c4b-84d8-4fbd-a3a2-909182680182" media="(prefers-color-scheme: dark)"><img src="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2FEXDg93iRaVsQ44fej5YO%2FGoogle_Play-Light.svg?alt=media&#x26;token=7a8727f2-285a-4841-b089-2a2f8b13d4bd" alt="Get it on Google Play"></picture></a></p>
### Pairing the sensor with the Aranet Home app
{% stepper %}
{% step %}
#### Tap “Add Sensor”
Open the app and tap the **Add Sensor** button in the top-right corner.
<figure><picture><source srcset="https://1419788306-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FWkQjwPV9Yi8oex9gapPt%2Fuploads%2FsWWAL5cgrYTNk4XRZee0%2Faranet2-pairing-1-dark-a.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://1419788306-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FWkQjwPV9Yi8oex9gapPt%2Fuploads%2FflSuzoV323ODIyRi7Snj%2Faranet2-pairing-1-light-a.png?alt=media" alt="Add Sensor button in the Aranet Home app" width="640"></picture><figcaption></figcaption></figure>
{% endstep %}
{% step %}
#### Find your sensor
The app will automatically search for nearby sensors. Once your sensor appears in the list, tap the blue **“Pair +”** button. The device number is shown on the sensor screen.
<figure><picture><source srcset="https://1419788306-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FWkQjwPV9Yi8oex9gapPt%2Fuploads%2F1kH5dorP5LVLfikODgwq%2Faranet2-pairing-2-dark-a.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://1419788306-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FWkQjwPV9Yi8oex9gapPt%2Fuploads%2FMoh3sRgS0XJ53oiyWMkV%2Faranet2-pairing-2-light-a.png?alt=media" alt="Finding the sensor in the list of nearby sensors" width="640"></picture><figcaption></figcaption></figure>
{% endstep %}
{% step %}
#### Pair your sensor
A Bluetooth pairing request will appear. Enter the pairing code displayed on your sensor to complete the pairing process.
<figure><picture><source srcset="https://1419788306-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FWkQjwPV9Yi8oex9gapPt%2Fuploads%2FadlFMp4Si1knJeYEIyuJ%2Faranet2-pairing-3-dark-a.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://1419788306-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FWkQjwPV9Yi8oex9gapPt%2Fuploads%2FLzRTlEyXHdje70mAyy0f%2Faranet2-pairing-3-light-a.png?alt=media" alt="Bluetooth pairing request" width="640"></picture><figcaption></figcaption></figure>
{% endstep %}
{% step %}
#### Start using your sensor
Once paired, your sensor is ready to use. A new sensor tile will automatically appear on your dashboard.
<figure><picture><source srcset="https://1419788306-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FWkQjwPV9Yi8oex9gapPt%2Fuploads%2FXaPp605fJyoV0HTtF7qo%2Faranet2-pairing-4-dark-a.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://1419788306-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FWkQjwPV9Yi8oex9gapPt%2Fuploads%2FlARfgPTOI2SJPm7x2Vop%2Faranet2-pairing-4-light-a.png?alt=media" alt="New sensor tile on the Aranet Home dashboard" width="640"></picture><figcaption></figcaption></figure>
{% endstep %}
{% endstepper %}
### Adjust measurement intervals
{% stepper %}
{% step %}
#### Open device settings
Open the Aranet Home app and go to **Device Settings**.
<figure><picture><source srcset="https://1419788306-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FWkQjwPV9Yi8oex9gapPt%2Fuploads%2FGCB6vq6FENAt0GHAPMmM%2Faranet2-interval-step1-world-dark.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://1419788306-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FWkQjwPV9Yi8oex9gapPt%2Fuploads%2F235HE3ZxnSkla3w8lIPW%2Faranet2-interval-step1-world.png?alt=media" alt="Device settings in the Aranet Home app" width="640"></picture><figcaption></figcaption></figure>
{% endstep %}
{% step %}
#### Choose the interval
Under **Measurement interval**, choose how often Aranet2 should measure temperature and humidity.
<figure><picture><source srcset="https://1419788306-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FWkQjwPV9Yi8oex9gapPt%2Fuploads%2FmioJ4mCzWUWZrKk65fEQ%2Faranet2-interval-step2-dark.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://1419788306-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FWkQjwPV9Yi8oex9gapPt%2Fuploads%2F43jAZ1it8kFudLBr97zx%2Faranet2-interval-step2.png?alt=media" alt="Measurement interval options" width="640"></picture><figcaption></figcaption></figure>
{% endstep %}
{% endstepper %}
Select the option that best fits your needs. Shorter intervals provide more frequent updates, while longer intervals help extend battery life.
### More information
For more about Aranet2 HOME, including measurements, settings, firmware, maintenance and FAQ, visit the [Aranet2 HOME help page](https://help.aranet.com/aranet2/aranet2-home.md).
Copyright © SAF Tehnika, JSC. All rights reserved.
App Store and the Apple logo are trademarks of Apple Inc., registered in the U.S. and other countries. Google Play and the Google Play logo are trademarks of Google LLC.
GET https://help.aranet.com/aranet2/aranet2-home/quick-start-guide.md?ask=<question>&goal=<user_goal>
