> For the complete documentation index, see [llms.txt](https://help.aranet.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://help.aranet.com/aranet2/aranet2-home/maintenance-and-safety/mounting-on-a-surface-or-wall.md).
# Mounting on a Surface or Wall
Such mounting is normal and will not affect the device measurement precision, as air vents are located on the sidewalls of the device body.
There is even a custom-made [**Aranet4 anti-theft wall mount**](https://aranet.com/en/pro/products/wall_mount_bracket) from us as the manufacturer that can be used to secure the device in its installation place. It also works with an Aranet2
<div data-with-frame="true"><img src="https://forum.aranet.com/site/assets/files/1798/flow2.577x0-is.png" alt=""></div>
GET https://help.aranet.com/aranet2/aranet2-home/maintenance-and-safety/mounting-on-a-surface-or-wall.md?ask=<question>&goal=<endgoal>
