> For the complete documentation index, see [llms.txt](https://help.aranet.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://help.aranet.com/aranet2/aranet2-home/documents-and-firmware/stuck-in-firmware-upgrade-mode.md).
# Stuck in Firmware Upgrade Mode
If your Aranet device gets stuck in firmware update, then follow these steps:\
NOTE: This only works from the Aranet Home app v3.4.2. As such, you should update your app before trying this.
1. Remove batteries and place them back after a few minutes.
2. Do “PAIR NEW DEVICE” from the application settings menu – the app will find the failed Aranet4 device and will start firmware recovery
<div data-with-frame="true"><figure><img src="/spaces/sryVHhsQqwlIEVjGZzRx/files/3rzBtn6e43ImjvVvCFI0" alt=""><figcaption></figcaption></figure></div>
GET https://help.aranet.com/aranet2/aranet2-home/documents-and-firmware/stuck-in-firmware-upgrade-mode.md?ask=<question>&goal=<endgoal>
