> For the complete documentation index, see [llms.txt](https://help.aranet.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://help.aranet.com/aranet-rn-one/aranet-radon-one/usage-and-measurements/placing-the-sensor.md). Agents can also search and read this documentation through its [MCP server](https://help.aranet.com/~gitbook/mcp).
# Placing the Sensor
For accurate readings, the **Aranet Radon One sensor** should be placed where radon is most likely to accumulate and where people actually spend time.
{% columns %}
{% column valign="middle" %}
In homes, this is typically the **lowest regularly occupied level** (such as a basement or ground floor). Position the device **0.5–2 meters (1.6–6.5 ft)** above the floor, in an open area with normal air circulation. Avoid placing it near windows, doors, ventilation outlets, or exterior walls, as drafts and fresh air can dilute radon levels and distort measurements
{% endcolumn %}
<div data-with-frame="true"><figure><img src="https://3048448099-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2Fb6ZpsMVJVtm3lJva9pRg%2Fuploads%2FTpmIMGbDuQUVPokMYDYo%2Fimage.png?alt=media&amp;token=b0081a49-7337-404e-8436-341f4c721938" alt="" width="188"><figcaption></figcaption></figure></div>
{% endcolumn %}
{% endcolumns %}
{% hint style="danger" %}
Do not place the sensor in kitchens, bathrooms, or directly next to heat sources or electronic devices.
{% hint style="success" %}
A stable, central location away from direct sunlight will provide the most representative long-term radon measurements.
Do not place the Aranet Radon One sensor in areas where it could be splashed with liquids or in high-humidity environments (above 85%), such as your bathroom. Place the sensor in a safe place where it cannot accidentally be dropped because it isn’t drop-proof.
GET https://help.aranet.com/aranet-rn-one/aranet-radon-one/usage-and-measurements/placing-the-sensor.md?ask=<question>&goal=<user_goal>
