> For the complete documentation index, see [llms.txt](https://help.aranet.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://help.aranet.com/aranet-rn-one/aranet-radon-one/aranet-home-app/notification-and-buzzer-settings.md).
# Notification and Buzzer Settings
#### Push notifications
Starting from Aranet Home App v3.8.2, push notifications can be enabled in the Aranet Home app settings. (Works better with background data read enabled)\
You will get periodic notifications if any of the sensors move past their configured thresholds.
#### Buzzer
The buzzer is an audio alarm built into all of the Aranet devices. When the buzzer is enabled (switched on), the "speaker" icon is visible on the Aranet display. It can be enabled behind the batteries as the second switch and in the Aranet Home app:
1. Navigate to sensor settings by pressing the "gear" icon;
<div data-with-frame="true"><figure><img src="/spaces/sryVHhsQqwlIEVjGZzRx/files/2HZyJDl623Ork6nhER7R" alt="" width="188"><figcaption></figcaption></figure></div>
2. Click on "Buzzer" to open the drop-down menu;
<div data-with-frame="true"><figure><img src="/spaces/sryVHhsQqwlIEVjGZzRx/files/BCBZrNAXDrh4shoiTJvQ" alt="" width="188"><figcaption></figcaption></figure></div>
3. Select the desired buzzer mode;
<div data-with-frame="true"><figure><img src="/spaces/sryVHhsQqwlIEVjGZzRx/files/YHjCOH1UeVlGyUPbkKMK" alt="" width="188"><figcaption></figcaption></figure></div>
4. After the mode change confirmation, exit sensor settings.
<div data-with-frame="true"><figure><img src="/spaces/sryVHhsQqwlIEVjGZzRx/files/EFfEgo3dMASrEpfF4csB" alt="" width="188"><figcaption></figcaption></figure></div>
GET https://help.aranet.com/aranet-rn-one/aranet-radon-one/aranet-home-app/notification-and-buzzer-settings.md?ask=<question>&goal=<endgoal>
