> For the complete documentation index, see [llms.txt](https://help.aranet.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://help.aranet.com/aranet-rn-one/aranet-radon-one/aranet-home-app/how-to-pair-with-the-aranet-home-app.md).
# How to Pair With the Aranet Home App
1. Download and install the latest Aranet Home app version:
* for iOS - <https://apps.apple.com/lv/app/aranet-home/id1392378465>
* for Android - <https://play.google.com/store/apps/details?id=com.saf.aranetCube.android&pcampaignid=web_share>
2. Launch the Aranet Home app.
<div data-with-frame="true"><figure><img src="/spaces/sryVHhsQqwlIEVjGZzRx/files/2yzMGPyvvsl3AHxFLJP5" alt="" width="188"><figcaption></figcaption></figure></div>
3. Stay close to your Aranet sensor and press “+ ADD NEW DEVICE” button:
4. When the application discovers your Aranet sensor, press “+ PAIR” button:
<div data-with-frame="true"><figure><img src="/spaces/sryVHhsQqwlIEVjGZzRx/files/1UhHWGwy76SUiA8qmEK7" alt="" width="188"><figcaption></figcaption></figure></div>
5\. Press “ACCEPT” button when the system asks for permission:
<div data-with-frame="true"><figure><img src="/spaces/sryVHhsQqwlIEVjGZzRx/files/cy7IKMuuKxxd2weXRcjU" alt="" width="188"><figcaption></figcaption></figure></div>
6\. At this moment the Aranet sensor will show **6-digit number** on its screen. This is the PIN code you should enter into the application screen:
<div data-with-frame="true"><figure><img src="/spaces/sryVHhsQqwlIEVjGZzRx/files/4lmukCJxgQXtpA7fwzjT" alt="" width="188"><figcaption></figcaption></figure></div>
The PIN code containing 6 random digits will look like this:
<div data-with-frame="true"><figure><img src="/spaces/sryVHhsQqwlIEVjGZzRx/files/qNyQfAEwJa71GprqxjNs" alt="" width="189"><figcaption></figcaption></figure></div>
Enter the PIN code in the pop-up window that appeared.
<div data-with-frame="true"><figure><img src="/spaces/sryVHhsQqwlIEVjGZzRx/files/FCtMWF83Lold2GQJMoXY" alt="" width="188"><figcaption></figcaption></figure></div>
7\. In a few seconds, after you have entered the code, the Aranet sensor should be paired to your phone:
<div data-with-frame="true"><figure><img src="/spaces/sryVHhsQqwlIEVjGZzRx/files/YNDXK5QTVi0uSQJcsy9Y" alt="" width="188"><figcaption></figcaption></figure></div>
GET https://help.aranet.com/aranet-rn-one/aranet-radon-one/aranet-home-app/how-to-pair-with-the-aranet-home-app.md?ask=<question>&goal=<endgoal>
