> For the complete documentation index, see [llms.txt](https://help.aranet.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://help.aranet.com/aranet-rn+/aranet-radon-plus/usage-and-measurements/default-settings.md).
# Default settings
When you first connect to the Aranet Home app, you can change the display units.
These are the default settings of the Aranet Radon Plus device:
{% columns %}
{% column valign="middle" %}
* The default measurement interval is 10 minutes.
* The default radon measurement unit is set to Bq/m<sup>3</sup>.
* The default temperature measurement unit is set to Celsius.
* Bluetooth connection is enabled.
* Bluetooth connection transmission range is set to normal.
* The buzzer for audio sound alarm notifications is disabled.
* Access to the Smart Home assistant is enabled.
  {% endcolumn %}
<div data-with-frame="true"><figure><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2F6qKr3ggdsJLXlhENATAb%2FWhatsApp%20Image%202026-10-23%20at%2009.57.10.jpeg?alt=media&amp;token=5e5f4ce7-65a1-46b2-8a57-6ce087626004" alt="" width="188"><figcaption></figcaption></figure></div>
{% endcolumn %}
{% endcolumns %}
#### Examples with measurements in °F and pCi/L
{% columns %}
{% column %}
<figure><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FaF7l1Qt1PDHj0B9OVNcu%2Fradon-plus-average-10min-usa-a.png?alt=media" alt="10 minutes averaging period, °F and pCi/L" width="100%"><figcaption><p>10 minutes</p></figcaption></figure>
{% endcolumn %}
{% column %}
<figure><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FN2lQjSSIg0xuqmktBJ7R%2Fradon-plus-average-24h-usa-a.png?alt=media" alt="24 hours averaging period, °F and pCi/L" width="100%"><figcaption><p>24 hours</p></figcaption></figure>
{% endcolumn %}
{% column %}
<figure><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FgfY6ckM9rXNSF0tUidSE%2Fradon-plus-average-7d-usa-a.png?alt=media" alt="7 days averaging period, °F and pCi/L" width="100%"><figcaption><p>7 days</p></figcaption></figure>
{% endcolumn %}
{% column %}
<figure><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FaxBXkTF83HNBT12FsL5i%2Fradon-plus-average-30d-usa-a.png?alt=media" alt="30 days averaging period, °F and pCi/L" width="100%"><figcaption><p>30 days</p></figcaption></figure>
{% endcolumn %}
{% endcolumns %}
#### Examples with measurements in °C and Bq/m³
{% columns %}
{% column %}
<figure><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FjOUOFN3AJFCDA3PsimFX%2Fradon-plus-average-10min-world-a.png?alt=media" alt="10 minutes averaging period, °C and Bq/m³" width="100%"><figcaption><p>10 minutes</p></figcaption></figure>
{% endcolumn %}
{% column %}
<figure><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2Fdk7XpwTb4qiL5E06UhoR%2Fradon-plus-average-24h-world-a.png?alt=media" alt="24 hours averaging period, °C and Bq/m³" width="100%"><figcaption><p>24 hours</p></figcaption></figure>
{% endcolumn %}
{% column %}
<figure><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2Fu4OYhaALOtXdWm0bPTHf%2Fradon-plus-average-7d-world-a.png?alt=media" alt="7 days averaging period, °C and Bq/m³" width="100%"><figcaption><p>7 days</p></figcaption></figure>
{% endcolumn %}
{% column %}
<figure><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FCJ7XDxhbsmA92Ih8LIKL%2Fradon-plus-average-30d-world-a.png?alt=media" alt="30 days averaging period, °C and Bq/m³" width="100%"><figcaption><p>30 days</p></figcaption></figure>
{% endcolumn %}
{% endcolumns %}
To enter the settings, press the switch inwards. To navigate the menu, push the switch up or down. Press the switch inwards again to choose an item.
{% columns %}
{% column width="41.67%" valign="middle" %}
<figure><picture><source srcset="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2F6ZMH9euN4FdeqEOkMPY0%2Fradon-plus-settings-menu-usa-dark-c.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FrEPkIFqEPp3QPF4Jl99k%2Fradon-plus-settings-menu-usa-c.png?alt=media" alt="Settings menu screen" width="100%"></picture><figcaption></figcaption></figure>
{% endcolumn %}
{% column width="58.33%" valign="middle" %}
In the settings, you can:
1. Reset the measurements
2. Change the buzzer status
3. Switch the Bluetooth signal on or off
4. Change the units for radon levels
5. Change the units for temperature
   {% endcolumn %}
   {% endcolumns %}
The Aranet Radon Plus is calibrated in the factory, and it works instantly when you take it out of the box and insert the batteries – no additional setup is needed.
More information about Aranet Radon Plus settings in the Aranet Home app: [Sensor Management](https://help.aranet.com/aranet-home-app/aranet-home-app/sensor-management-tiles.md#aranet-radon-plus)
GET https://help.aranet.com/aranet-rn+/aranet-radon-plus/usage-and-measurements/default-settings.md?ask=<question>&goal=<user_goal>
