> For the complete documentation index, see [llms.txt](https://help.aranet.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://help.aranet.com/aranet-rn+/aranet-radon-plus/quick-start-guide.md).
# Quick Start Guide
Get started with your Aranet Radon Plus sensor: display, setup, settings and pairing with the Aranet Home app.
{% hint style="info" %}
🌐 Also available in: [Nederlands](https://help.aranet.com/aranet-rn+/nl/aranet-radon-plus/quick-start-guide) · [Français](https://help.aranet.com/aranet-rn+/fr/aranet-radon-plus/quick-start-guide) · [Deutsch](https://help.aranet.com/aranet-rn+/de/aranet-radon-plus/quick-start-guide)
<figure><picture><source srcset="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FCynfTziDAhtLo89kq7DD%2Fradon-plus-hero-usa-dark-c-bat2.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FpkkI8iET8eYsQ8PQoy7l%2Fradon-plus-hero-usa-c-bat2.png?alt=media" alt="Aranet Radon Plus – Quick Start Guide" width="100%"></picture><figcaption></figcaption></figure>
### What does Aranet Radon Plus measure?
**Radon gas** is colorless, odorless and hard to detect, posing serious health risks. It escapes from the ground into the air and can accumulate in your home. According to the [World Health Organization](https://www.who.int/news-room/fact-sheets/detail/radon-and-health), radon is one of the leading causes of lung cancer. Because radon levels can fluctuate, regular radon monitoring is vital.
The Aranet Radon Plus sensor offers real-time radon monitoring. With wireless functionality and quality components, it ensures accurate measurements. The E-Ink display and long battery life make it ideal for continuous indoor air quality monitoring.
#### Temperature
The optimal indoor temperature ranges from 18 to 24 °C / 64 to 75 °F.
#### Relative humidity
The ideal relative humidity is between 30–50 % indoors. Low humidity (< 30 %) can cause skin to get dry and irritable. Environments that are too humid (> 50 %) cause bacteria and mold to breed.
### Display and switch
<figure><picture><source srcset="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2Fm0uZ1823WQiOmhl7VlJr%2Fradon-plus-display-usa-dark-c-bat2.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FwYjLwoJgVXToAKsaQQgi%2Fradon-plus-display-usa-c-bat2.png?alt=media" alt="Aranet Radon Plus display with numbered callouts" width="640"></picture><figcaption></figcaption></figure>
1. Temperature (°C, °F)
2. Averaging period for measurement (24h, 7d, 30d)
3. Battery level
4. Device number
5. Relative humidity (%)
6. Radon level
7. Radon level units (pCi/L, Bq/m³)
8. Buzzer status (if this symbol is not visible, the buzzer is switched off)
9. Radon threshold indication
10. Action switch (press to enter the menu, or push up and down to switch measurement types)
### Radon level color coding
{% columns %}
{% column %}
<figure><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FJEzI7x0wG6HvzrsRJZMs%2Fradon-plus-level-green-usa-c-bat2.png?alt=media" alt="Green" width="100%"><figcaption></figcaption></figure>
#### <img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FWtJOUXJ4O0FNvaMT1ENS%2Flevel-dot-green.svg?alt=media" alt="" data-size="line"> Green
#### Under 2.7 pCi/L
Under 100 Bq/m³
Recommended by WHO as national reference for annual average residential radon concentration.
{% endcolumn %}
{% column %}
<figure><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FquH2yjD3CipEZMSFJM7H%2Fradon-plus-level-yellow-usa-c-bat2.png?alt=media" alt="Yellow" width="100%"><figcaption></figcaption></figure>
#### <img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FSRTcI1rmhWwHprclUnL8%2Flevel-dot-yellow.svg?alt=media" alt="" data-size="line"> Yellow
#### 2.7 pCi/L to 8.1 pCi/L
100 Bq/m³ to 300 Bq/m³
Recommended by WHO as national reference annual average residential radon concentration even for countries with specific conditions.
{% endcolumn %}
{% column %}
<figure><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FzBNmyM9geV0TkPwbzx6U%2Fradon-plus-level-red-usa-c-bat2.png?alt=media" alt="Red" width="100%"><figcaption></figcaption></figure>
#### <img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FcWEUtXcDT4d3Ji2U51FW%2Flevel-dot-red.svg?alt=media" alt="" data-size="line"> Red
#### Above 8.1 pCi/L
Above 300 Bq/m³
Prolonged exposure to such radon concentrations is linked to health problems.
{% endcolumn %}
{% endcolumns %}
These are the default thresholds. You can change them in the Aranet Home app.
A dot on the threshold indicator means that you have set your own threshold in the Aranet Home app.
### Setting up the device
1. Insert the batteries, making sure the polarity is correct.
2. Press the switch to continue.
<figure><picture><source srcset="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FWa5MIn7xTrjFzFnlkNxb%2Fradon-plus-batteries-dark-a.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FlJtLPpzQ48bM6IRqpLhu%2Fradon-plus-batteries-a.png?alt=media" alt="Inserting batteries and the first start screen" width="542"></picture><figcaption></figcaption></figure>
3. Wait 10 minutes for the first measurement to appear.
{% columns %}
{% column %}
<figure><picture><source srcset="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FyCM7Ni126aslPbJhN5z1%2Fradon-plus-state-please-wait-usa-dark-c-bat2.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FOUO14Ab2vDRh2dOedx0z%2Fradon-plus-state-please-wait-usa-c-bat2.png?alt=media" alt="Measuring: 0/10 min" width="100%"></picture><figcaption></figcaption></figure>
<img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FcWEUtXcDT4d3Ji2U51FW%2Flevel-dot-red.svg?alt=media" alt="" data-size="line"> **Please wait** – measuring
{% endcolumn %}
{% column %}
<figure><picture><source srcset="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2Fc3F1BItJzuLZ9lnjtud2%2Fradon-plus-state-refining-usa-dark-c-bat2.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2F3mB6zO7dy9yl0HanrwAX%2Fradon-plus-state-refining-usa-c-bat2.png?alt=media" alt="Refining data" width="100%"></picture><figcaption></figcaption></figure>
<img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FSRTcI1rmhWwHprclUnL8%2Flevel-dot-yellow.svg?alt=media" alt="" data-size="line"> **Refining data** – readings are not yet accurate
{% endcolumn %}
{% column %}
<figure><picture><source srcset="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FjJjqKMvq3Wjh5aQMdk2P%2Fradon-plus-state-ready-usa-dark-c-bat2.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FNcbOdLTzjNSpdcw6EZCG%2Fradon-plus-state-ready-usa-c-bat2.png?alt=media" alt="Measurement ready" width="100%"></picture><figcaption></figcaption></figure>
<img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FWtJOUXJ4O0FNvaMT1ENS%2Flevel-dot-green.svg?alt=media" alt="" data-size="line"> **Ready to use**
{% endcolumn %}
{% endcolumns %}
It takes 1 hour for the sensor to reach full measurement accuracy.
If the sensor's operating time is shorter than the selected averaging period, a status indicator is shown on the display.
While an average is still being collected, the display switches back to the current reading automatically. This is intended behaviour.
{% columns %}
{% column %}
<figure><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2Fbt7HpfoVT31DcpcnZcoN%2Fradon-plus-status-now-usa-c-bat2.png?alt=media" alt="Current radon reading" width="100%"><figcaption><p>Current reading</p></figcaption></figure>
{% endcolumn %}
{% column %}
<figure><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FmgYR3drRQ4Gd86Lksejg%2Fradon-plus-status-24h-usa-c-bat2.png?alt=media" alt="24h average in progress" width="100%"><figcaption><p>24h average – measuring</p></figcaption></figure>
{% endcolumn %}
{% column %}
<figure><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FKanSKL7PD1UW92ZtFS6J%2Fradon-plus-status-7d-usa-c-bat2.png?alt=media" alt="7d average in progress" width="100%"><figcaption><p>7d average – measuring</p></figcaption></figure>
{% endcolumn %}
{% column %}
<figure><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2Ff7WONMTsoDIyEpZ0ZCwq%2Fradon-plus-status-30d-usa-c-bat2.png?alt=media" alt="30d average in progress" width="100%"><figcaption><p>30d average – measuring</p></figcaption></figure>
{% endcolumn %}
{% endcolumns %}
{% hint style="warning" %}
**Caution:** if the sensor is exposed to humidity over 85 %, a high humidity message appears on the screen. Place the sensor in a drier location and it will resume normal operation.
<figure><picture><source srcset="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FIymFqwUuIxmq2jG5cCLI%2Frnp_hum-Dark-bat2.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FpOKRMQVjbP9nzdKgIVQt%2Frnp_hum-Light-bat2.png?alt=media" alt="High humidity message on the display"></picture><figcaption></figcaption></figure>
### Configuration of the device
<figure><picture><source srcset="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FwYZk3gxfSoWJ1EGNfdQG%2Fradon-plus-switches-dark-a.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FMjF2VMcrrcSZQsuzrP19%2Fradon-plus-switches-a.png?alt=media" alt="Action switch on the side of the sensor" width="640"></picture><figcaption></figcaption></figure>
* To change the radon levels displayed for different averaging periods (10 min, 24h, 7d, 30d), push the switch up or down.
* To enter the settings, press the switch inwards.
* Most of the settings are configurable in the Aranet Home app.
### Settings menu
Push the switch up or down to select the radon level averaging period: 10 minutes, 24 hours, 7 days or 30 days.
#### Examples with measurements in °F and pCi/L
{% columns %}
{% column %}
<figure><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FW7SSLlJFrTaDYEABRLqH%2Fradon-plus-average-10min-usa-a-bat2.png?alt=media" alt="10 minutes averaging period, °F and pCi/L" width="100%"><figcaption><p>10 minutes</p></figcaption></figure>
{% endcolumn %}
{% column %}
<figure><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FawIJJOU0hs45w2qwI596%2Fradon-plus-average-24h-usa-a-bat2.png?alt=media" alt="24 hours averaging period, °F and pCi/L" width="100%"><figcaption><p>24 hours</p></figcaption></figure>
{% endcolumn %}
{% column %}
<figure><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2Fow8lg81p2vuDhQDy9qVa%2Fradon-plus-average-7d-usa-a-bat2.png?alt=media" alt="7 days averaging period, °F and pCi/L" width="100%"><figcaption><p>7 days</p></figcaption></figure>
{% endcolumn %}
{% column %}
<figure><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FC77TLCIinwP9MV4oXmI1%2Fradon-plus-average-30d-usa-a-bat2.png?alt=media" alt="30 days averaging period, °F and pCi/L" width="100%"><figcaption><p>30 days</p></figcaption></figure>
{% endcolumn %}
{% endcolumns %}
#### Examples with measurements in °C and Bq/m³
{% columns %}
{% column %}
<figure><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FyeWKJyRHDNorIalEtV26%2Fradon-plus-average-10min-world-a-bat2.png?alt=media" alt="10 minutes averaging period, °C and Bq/m³" width="100%"><figcaption><p>10 minutes</p></figcaption></figure>
{% endcolumn %}
{% column %}
<figure><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FFPMlMywVEt9NmVVYc1rn%2Fradon-plus-average-24h-world-a-bat2.png?alt=media" alt="24 hours averaging period, °C and Bq/m³" width="100%"><figcaption><p>24 hours</p></figcaption></figure>
{% endcolumn %}
{% column %}
<figure><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2F2lKnA2zwjRL1r4C7EX2C%2Fradon-plus-average-7d-world-a-bat2.png?alt=media" alt="7 days averaging period, °C and Bq/m³" width="100%"><figcaption><p>7 days</p></figcaption></figure>
{% endcolumn %}
{% column %}
<figure><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FVbN1sIESNMKgdA8qUdbf%2Fradon-plus-average-30d-world-a-bat2.png?alt=media" alt="30 days averaging period, °C and Bq/m³" width="100%"><figcaption><p>30 days</p></figcaption></figure>
{% endcolumn %}
{% endcolumns %}
To enter the settings, press the switch inwards. To navigate the menu, push the switch up or down. Press the switch inwards again to choose an item.
{% columns %}
{% column width="41.67%" valign="middle" %}
<figure><picture><source srcset="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2F6ZMH9euN4FdeqEOkMPY0%2Fradon-plus-settings-menu-usa-dark-c.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FrEPkIFqEPp3QPF4Jl99k%2Fradon-plus-settings-menu-usa-c.png?alt=media" alt="Settings menu screen" width="100%"></picture><figcaption></figcaption></figure>
{% endcolumn %}
{% column width="58.33%" valign="middle" %}
In the settings you can:
1. Reset the measurements
2. Change the buzzer status
3. Switch the Bluetooth signal on or off
4. Change the units for radon levels
5. Change the units for temperature
   {% endcolumn %}
   {% endcolumns %}
{% columns %}
<figure><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2Fq4hZBVZVo4n8Bkk4nucV%2Fradon-plus-reset-menu-usa-c.png?alt=media" alt="Reset the measurement history" width="100%"><figcaption></figcaption></figure>
{% endcolumn %}
{% hint style="danger" %}
When a reset is performed, the data is permanently lost. Reset the history only if:
* the device was passed to you by someone else and the data does not apply to you anymore, or
* you want to start fresh, for example at the beginning of a new year.
Resetting clears only the data stored on the sensor. To also clear the graphs in the Aranet Home app, remove the sensor from the app and add it again.
{% endcolumn %}
{% endcolumns %}
For more technical information, see the [Aranet Radon Plus sensor data sheet](https://aranet.com/downloads/aranet-radon-plus-home-datasheet).
### Aranet Home app
Download the Aranet Home app from the App Store or Google Play. You can scan the QR code with your phone camera or go to [aranet.com/aranet-home-app](https://aranet.com/aranet-home-app).
Each sensor also has its Quick Start Guide inside the Aranet Home app.
<figure><picture><source srcset="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FFh9xDzEv7C2JGLw4mOOn%2FRegion%3DWorld%2C%20Mode%3DDark.png?alt=media&amp;token=9c34f750-ba12-4bc5-b059-1e9d07df5b28" media="(prefers-color-scheme: dark)"><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FMpR4mLTebk3BPqEREC6f%2FAranet%20Home%20app.png?alt=media&amp;token=d25c774b-a2fe-4111-a4e3-dbcaa52313a3" alt="Aranet Home app with QR code"></picture><figcaption></figcaption></figure>
<p align="center"><a href="https://apps.apple.com/us/app/aranet4/id1392378465"><picture><source srcset="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2FsSwL7Hxr8xqqBYg9zOO8%2FApp_Store-Dark.svg?alt=media&#x26;token=2ff107bc-81e7-43f1-97e7-be9df4795f25" media="(prefers-color-scheme: dark)"><img src="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2FVll57HuYqvjAULp2Qzgt%2FApp_Store-Light.svg?alt=media&#x26;token=8a745dd9-97cf-4783-89b7-b935eeccb9b1" alt="Download on the App Store"></picture></a> <a href="https://play.google.com/store/apps/details?id=com.saf.aranetCube.android"><picture><source srcset="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2F1iYoLFG3LrvXMcwSNUkh%2FGoogle_Play-Dark.svg?alt=media&#x26;token=153a5c4b-84d8-4fbd-a3a2-909182680182" media="(prefers-color-scheme: dark)"><img src="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2FEXDg93iRaVsQ44fej5YO%2FGoogle_Play-Light.svg?alt=media&#x26;token=7a8727f2-285a-4841-b089-2a2f8b13d4bd" alt="Get it on Google Play"></picture></a></p>
### Pairing the sensor with the Aranet Home app
{% stepper %}
{% step %}
#### Tap “Add Sensor”
Open the app and tap the **Add Sensor** button in the top-right corner.
<figure><picture><source srcset="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FOPxf1c6zX2ZL1zx4RDlY%2Fradon-plus-pairing-1-dark-a.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FLw6X5W2epsuhG9bRa1Sd%2Fradon-plus-pairing-1-a.png?alt=media" alt="Add Sensor button in the Aranet Home app" width="640"></picture><figcaption></figcaption></figure>
{% endstep %}
{% step %}
#### Find your sensor
The app will automatically search for nearby sensors. Once your sensor appears in the list, tap the blue **“Pair +”** button. The device number is shown on the sensor screen.
<figure><picture><source srcset="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FSGrbLh0XnMjwycZxLFtU%2Fradon-plus-pairing-2-world-dark-a.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FDqLHjh6CG0c4gN2MJpdw%2Fradon-plus-pairing-2-world-a.png?alt=media" alt="Finding the sensor in the list of nearby sensors"></picture><figcaption></figcaption></figure>
{% endstep %}
{% step %}
#### Pair your sensor
A Bluetooth pairing request will appear. Enter the pairing code displayed on your sensor to complete the pairing process. Do not press anything on the sensor until pairing is complete.
<figure><picture><source srcset="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FDUFMBnhXFB4QnkaQpahm%2Fradon-plus-pairing-3-dark-a.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FjfGf5fZiotxmpakIU1qG%2Fradon-plus-pairing-3-a.png?alt=media" alt="Bluetooth pairing request" width="640"></picture><figcaption></figcaption></figure>
{% endstep %}
{% step %}
#### Start using your sensor
Once paired, your sensor is ready to use. A new sensor tile will automatically appear on your dashboard.
<figure><picture><source srcset="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FcUKaSD7hEivBGxsCXccf%2Fradon-plus-pairing-4-world-dark-a.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2Fwj5m904n9zbxlweYPiAf%2Fradon-plus-pairing-4-world-a.png?alt=media" alt="New sensor tile on the Aranet Home dashboard"></picture><figcaption></figcaption></figure>
{% endstep %}
{% endstepper %}
### More information
For more about Aranet Radon Plus, including measurements, settings, firmware, maintenance and FAQ, visit the [Aranet Radon Plus help page](https://help.aranet.com/aranet-rn+/aranet-radon-plus.md).
Copyright © SAF Tehnika, JSC. All rights reserved.
App Store and the Apple logo are trademarks of Apple Inc., registered in the U.S. and other countries. Google Play and the Google Play logo are trademarks of Google LLC.
GET https://help.aranet.com/aranet-rn+/aranet-radon-plus/quick-start-guide.md?ask=<question>&goal=<user_goal>
