> For the complete documentation index, see [llms.txt](https://help.aranet.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://help.aranet.com/aranet-rn+/aranet-radon-plus/manuals-and-firmware/how-to-update-firmware.md). Agents can also search and read this documentation through its [MCP server](https://help.aranet.com/~gitbook/mcp).
# Updating Firmware
Starting with Aranet Home app version v2.0, a firmware update can be done as follows:
{% columns %}
{% column valign="middle" %}
Locate the sensor you need to perform the update on. Then click on the three-dot icon and find *Device Settings.*
Scroll down and find the *Firmware Update* option and press it.
In the next window, if there is an update, you will be able to perform one. If not, then a message *Up to date* will be displayed.
{% endcolumn %}
{% column %}
<div data-with-frame="true"><figure><img src="https://1201590045-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FEmn83sm3fwM9elVam8x2%2Fuploads%2FK0iWLlRwhpDriZEOuzQt%2Ffirmware-update.gif?alt=media" alt="" width="135"><figcaption></figcaption></figure></div>
{% endcolumn %}
{% endcolumns %}
{% hint style="info" %}
Sometimes there might be an issue where the sensor is stuck during some operation, for example, a firmware upgrade.
If you are stuck in the update process, it is advised to open the Aranet Home app and try to add a new sensor. In most cases, this sensor will be discovered, paired back to the app, and working again. If the issue still persists, please contact <support@aranet.com> or refer to the information in another topic: [Firmware Update Issues](https://help.aranet.com/aranet-rn+/aranet-radon-plus/manuals-and-firmware/stuck-in-firmware-upgrade-mode.md)
GET https://help.aranet.com/aranet-rn+/aranet-radon-plus/manuals-and-firmware/how-to-update-firmware.md?ask=<question>&goal=<user_goal>
