> For the complete documentation index, see [llms.txt](https://help.aranet.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://help.aranet.com/aranet-radiation-sensor/aranet-radiation-sensor/quick-start-guide.md). Agents can also search and read this documentation through its [MCP server](https://help.aranet.com/~gitbook/mcp).
# Quick Start Guide
Get started with your Aranet Radiation sensor: dose rate, total dose, display, setup and pairing with the Aranet Home app.
{% hint style="info" %}
🌐 Also available in: [Nederlands](https://help.aranet.com/aranet-radiation-sensor/nl/aranet-radiation-sensor/quick-start-guide) · [Français](https://help.aranet.com/aranet-radiation-sensor/fr/aranet-radiation-sensor/quick-start-guide) · [Deutsch](https://help.aranet.com/aranet-radiation-sensor/de/aranet-radiation-sensor/quick-start-guide)
<figure><picture><source srcset="https://3348039115-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FgM7507pq0wfMQak6jy2F%2Fuploads%2FmJ3g9WV6rK8tUriyzQV4%2Fradiation-hero-dark-a-id.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://3348039115-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FgM7507pq0wfMQak6jy2F%2Fuploads%2F2PeCTqifSWuaezV3Fcm0%2Fradiation-hero-light-a-id.png?alt=media" alt="Aranet Radiation – Quick Start Guide" width="100%"></picture><figcaption></figcaption></figure>
### What does Aranet Radiation measure?
**Dose rate** describes how strong the ionizing radiation (γ, β) is at a given moment. It is expressed in microsieverts per hour (μSv/h) or millirems per hour (mrem/h).
If radiation levels rise, the device uses colors (green, yellow and red) to alert you, dimming the screen for high values (red level). The default threshold levels are based on scientific recommendations[^1].
{% columns %}
{% column %}
<figure><img src="https://3348039115-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FgM7507pq0wfMQak6jy2F%2Fuploads%2Fa2EzTQS7zMtSiFh8YvYL%2Fradiation-level-green-world-b-id.png?alt=media" alt="Aranet Radiation screen at green level" width="100%"><figcaption></figcaption></figure>
#### <img src="https://3348039115-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FgM7507pq0wfMQak6jy2F%2Fuploads%2FgUbDZ7BYfaaNZATG4O43%2Flevel-dot-green.svg?alt=media" alt="" data-size="line"> Green
#### Below 0.20 μSv/h
Normal background radiation.
{% endcolumn %}
{% column %}
<figure><img src="https://3348039115-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FgM7507pq0wfMQak6jy2F%2Fuploads%2Fw4ELtuDtah6MXEu7JlzF%2Fradiation-level-yellow-world-b-id.png?alt=media" alt="Aranet Radiation screen at yellow level" width="100%"><figcaption></figcaption></figure>
#### <img src="https://3348039115-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FgM7507pq0wfMQak6jy2F%2Fuploads%2F3ToAj8aZV5Ps8H9pw7Y1%2Flevel-dot-yellow.svg?alt=media" alt="" data-size="line"> Yellow
#### 0.20–10.0 μSv/h
Radiation above typical background levels.
{% endcolumn %}
{% column %}
<figure><img src="https://3348039115-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FgM7507pq0wfMQak6jy2F%2Fuploads%2F9IzgqUMBmgCqov2ngP9Y%2Fradiation-level-red-world-b-id.png?alt=media" alt="Aranet Radiation screen at red level" width="100%"><figcaption></figcaption></figure>
#### <img src="https://3348039115-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FgM7507pq0wfMQak6jy2F%2Fuploads%2Fk3azT8EPitXp69uFZ1Pu%2Flevel-dot-red.svg?alt=media" alt="" data-size="line"> Red
#### Above 10.0 μSv/h
Prolonged exposure to such radiation levels is linked to health problems.
{% endcolumn %}
{% endcolumns %}
These are the default thresholds. You can change them in the Aranet Home app.
**Total dose** of ionizing radiation (γ, β) encountered during the integration time is expressed in millisieverts (mSv) or rems (rem). Total dose is a critical metric for ensuring environmental safety and personal health. If the average rate at which the total dose has been acquired exceeds 0.20 μSv/h, the upper part of the screen is dimmed.
This reading can be reset from the Aranet Home app or by pushing the mechanical button behind the battery compartment lid. To perform a reset, press and hold the button for 5 seconds.
### Display
<figure><picture><source srcset="https://3348039115-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FgM7507pq0wfMQak6jy2F%2Fuploads%2FaSDmT7pp6z89rOj5VJAt%2Fradiation-display-dark-a.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://3348039115-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FgM7507pq0wfMQak6jy2F%2Fuploads%2FUMglnsMb3kiJ6WNWs8J0%2Fradiation-display-light-a.png?alt=media" alt="Aranet Radiation display with numbered callouts" width="640"></picture><figcaption></figcaption></figure>
1. Total dose
2. Dose rate
3. Battery level
4. Device number
5. Integration time
6. Dose rate
7. Dose rate threshold indication
### Resetting the total dose
{% hint style="danger" %}
When a reset is performed, the data is permanently lost. Reset the history only if:
* the device was passed to you by someone else and the data does not apply to you anymore, or
* you want to start fresh, for example at the beginning of a new year.
<figure><picture><source srcset="https://3348039115-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FgM7507pq0wfMQak6jy2F%2Fuploads%2FoUcbiQR2zGPSHxh1EOk8%2Fradiation-reset-dark-a.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://3348039115-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FgM7507pq0wfMQak6jy2F%2Fuploads%2FlXqMF4HnblxlJLd1M7ZS%2Fradiation-reset-light-a.png?alt=media" alt="Reset button behind the battery compartment lid" width="639"></picture><figcaption></figcaption></figure>
1. Sensor – do not remove the sticker (sensor to surface distance 15 mm)
The reset button is marked in red. Press and hold it for 5 seconds to reset the total dose.
### Setting up the device
Insert the batteries, and your Aranet Radiation device is ready to go. Please wait a few minutes for the first measurement to appear.
{% columns %}
{% column %}
<figure><picture><source srcset="https://3348039115-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FgM7507pq0wfMQak6jy2F%2Fuploads%2F8OAAbqlu4YQG27Q62aWt%2Fradiation-state-wait-dark-a-bat2.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://3348039115-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FgM7507pq0wfMQak6jy2F%2Fuploads%2FOOQvF78xvGd8GCXDM9pZ%2Fradiation-state-wait-light-a-bat2.png?alt=media" alt="Refining data" width="167"></picture><figcaption><p>🔴 <strong>Please wait</strong> – refining data</p></figcaption></figure>
{% endcolumn %}
{% column %}
<figure><picture><source srcset="https://3348039115-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FgM7507pq0wfMQak6jy2F%2Fuploads%2Fyw4L3BEAykta56k6bGsV%2Fradiation-state-ready-dark-a-id.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://3348039115-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FgM7507pq0wfMQak6jy2F%2Fuploads%2FSOiyIQIpkHdGwpyjnfiV%2Fradiation-state-ready-light-a-id.png?alt=media" alt="Measurement ready" width="168"></picture><figcaption><p>🟢 <strong>Ready to use</strong></p></figcaption></figure>
{% endcolumn %}
{% endcolumns %}
{% hint style="warning" %}
#### Caution
* Do not remove the sticker on the back of the Aranet Radiation sensor.
* Aranet Radiation is not impact-resistant. Exposure to strong accelerations can lead to erroneous measurements.
* Do not expose Aranet Radiation to high-humidity environments.
* Exposing the sensor to X-ray scans, like those at airport baggage controls, temporarily raises the dose rate and total dose readings. These can be disregarded, or avoided by removing the sensor batteries during scans.
### Configuration switches
The switches can be found behind the batteries. Use the attached pin to adjust these settings:
<figure><picture><source srcset="https://3348039115-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FgM7507pq0wfMQak6jy2F%2Fuploads%2FMGsvIeBUhTaNHvAuqenO%2Fradiation-config-switches-dark-v3-buzzer.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://3348039115-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FgM7507pq0wfMQak6jy2F%2Fuploads%2FFjbsKOdsoVhLV0MlX9Z3%2Fradiation-config-switches-light-v3-buzzer.png?alt=media" alt="Aranet Radiation configuration switches with numbered callouts" width="640"></picture><figcaption></figcaption></figure>
1. **Unit switch:** Sv (SI unit, default) or rem
2. **Pulse buzzer:** on (default) or off. When this feature is on, the device beeps every time it detects an ionizing radiation event, similar to a Geiger counter. More frequent beeps indicate higher radiation levels.
3. **Bluetooth:** on (default) or off
4. **Connection to Aranet base stations / LoRa transmission:** non-functional for HOME sensors
For more technical information, see the [Aranet Radiation sensor data sheet](https://aranet.com/downloads/aranet-radiation-home-datasheet).
### Aranet Home app
Download the Aranet Home app from the App Store or Google Play. You can scan the QR code with your phone camera or go to [aranet.com/aranet-home-app](https://aranet.com/aranet-home-app).
Each sensor also has its Quick Start Guide inside the Aranet Home app.
<figure><picture><source srcset="https://3348039115-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FgM7507pq0wfMQak6jy2F%2Fuploads%2FTaJZefHwnDYSnbl0uE0h%2Fradiation-app-dark-a.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://3348039115-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FgM7507pq0wfMQak6jy2F%2Fuploads%2FdGGaJnsKd3Y3QBA0TQ8P%2Fradiation-app-light-a.png?alt=media" alt="Aranet Home app with QR code" width="640"></picture><figcaption></figcaption></figure>
<p align="center"><a href="https://apps.apple.com/us/app/aranet4/id1392378465"><picture><source srcset="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2FsSwL7Hxr8xqqBYg9zOO8%2FApp_Store-Dark.svg?alt=media&#x26;token=2ff107bc-81e7-43f1-97e7-be9df4795f25" media="(prefers-color-scheme: dark)"><img src="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2FVll57HuYqvjAULp2Qzgt%2FApp_Store-Light.svg?alt=media&#x26;token=8a745dd9-97cf-4783-89b7-b935eeccb9b1" alt="Download on the App Store"></picture></a> <a href="https://play.google.com/store/apps/details?id=com.saf.aranetCube.android"><picture><source srcset="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2F1iYoLFG3LrvXMcwSNUkh%2FGoogle_Play-Dark.svg?alt=media&#x26;token=153a5c4b-84d8-4fbd-a3a2-909182680182" media="(prefers-color-scheme: dark)"><img src="https://3323570029-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FsryVHhsQqwlIEVjGZzRx%2Fuploads%2FEXDg93iRaVsQ44fej5YO%2FGoogle_Play-Light.svg?alt=media&#x26;token=7a8727f2-285a-4841-b089-2a2f8b13d4bd" alt="Get it on Google Play"></picture></a></p>
### Pairing the sensor with the Aranet Home app
{% stepper %}
{% step %}
#### Tap “Add Sensor”
Open the app and tap the **Add Sensor** button in the top-right corner.
<figure><picture><source srcset="https://3348039115-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FgM7507pq0wfMQak6jy2F%2Fuploads%2F4TavmPw3eYXlVlnaubNz%2Fradiation-pairing-1-dark-a.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://3348039115-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FgM7507pq0wfMQak6jy2F%2Fuploads%2F6iOd7MRHXlLycz57W6Ww%2Fradiation-pairing-1-light-a.png?alt=media" alt="Add Sensor button in the Aranet Home app" width="640"></picture><figcaption></figcaption></figure>
{% endstep %}
{% step %}
#### Find your sensor
The app will automatically search for nearby sensors. Once your sensor appears in the list, tap the blue **“Pair +”** button. The device number is shown on the sensor screen.
<figure><picture><source srcset="https://3348039115-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FgM7507pq0wfMQak6jy2F%2Fuploads%2FEWh30RLLALh2McWHR1rP%2Fradiation-pairing-2-dark-a.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://3348039115-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FgM7507pq0wfMQak6jy2F%2Fuploads%2FCcpVSRZU7IGjfyh291e4%2Fradiation-pairing-2-light-a.png?alt=media" alt="Finding the sensor in the list of nearby sensors" width="640"></picture><figcaption></figcaption></figure>
{% endstep %}
{% step %}
#### Pair your sensor
A Bluetooth pairing request will appear. Enter the pairing code displayed on your sensor to complete the pairing process.
<figure><picture><source srcset="https://3348039115-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FgM7507pq0wfMQak6jy2F%2Fuploads%2F3x5974v4ylW7R7TUJGuA%2Fradiation-pairing-3-dark-a.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://3348039115-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FgM7507pq0wfMQak6jy2F%2Fuploads%2FZQgKLlMmouxi9mbfdWnw%2Fradiation-pairing-3-light-a.png?alt=media" alt="Bluetooth pairing request" width="640"></picture><figcaption></figcaption></figure>
{% endstep %}
{% step %}
#### Start using your sensor
Once paired, your sensor is ready to use. A new sensor tile will automatically appear on your dashboard.
<figure><picture><source srcset="https://3348039115-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FgM7507pq0wfMQak6jy2F%2Fuploads%2Fpewws7JIhx6DyB0v6oDJ%2Fradiation-pairing-4-dark-a.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://3348039115-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FgM7507pq0wfMQak6jy2F%2Fuploads%2FDBSMe5pl2jUzbmqwS1vj%2Fradiation-pairing-4-light-a.png?alt=media" alt="New sensor tile on the Aranet Home dashboard" width="640"></picture><figcaption></figcaption></figure>
{% endstep %}
{% endstepper %}
### Adjust measurement intervals
{% stepper %}
{% step %}
#### Open device settings
Open the Aranet Home app and go to **Device Settings**.
<figure><picture><source srcset="https://3348039115-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FgM7507pq0wfMQak6jy2F%2Fuploads%2FymcenR7PB2jBampJht50%2Fradiation-interval-step1-dark.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://3348039115-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FgM7507pq0wfMQak6jy2F%2Fuploads%2FZ3dk0UGaxLOZ0wt2tT9M%2Fradiation-interval-step1.png?alt=media" alt="Device settings in the Aranet Home app" width="640"></picture><figcaption></figcaption></figure>
{% endstep %}
{% step %}
#### Choose the interval
Under **Measurement interval**, choose how often the sensor should record the dose rate.
<figure><picture><source srcset="https://3348039115-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FgM7507pq0wfMQak6jy2F%2Fuploads%2F85VXBqIYDXSvUiUCVuLf%2Fradiation-interval-step2-dark.png?alt=media" media="(prefers-color-scheme: dark)"><img src="https://3348039115-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FgM7507pq0wfMQak6jy2F%2Fuploads%2FESdrkZQsvBfgYx2luNik%2Fradiation-interval-step2.png?alt=media" alt="Measurement interval options" width="640"></picture><figcaption></figcaption></figure>
{% endstep %}
{% endstepper %}
Select the option that best fits your needs. Shorter intervals give a more detailed dose rate history, while longer intervals help extend battery life.
### More information
For more about Aranet Radiation, including measurements, settings, firmware, maintenance and FAQ, visit the [Aranet Radiation help page](https://help.aranet.com/aranet-radiation-sensor/aranet-radiation-sensor.md).
Copyright © SAF Tehnika, JSC. All rights reserved.
App Store and the Apple logo are trademarks of Apple Inc., registered in the U.S. and other countries. Google Play and the Google Play logo are trademarks of Google LLC.
[^1]: [EURDEP Gamma Dose Rates Advanced Map](https://remap.jrc.ec.europa.eu/Consent/Advanced.aspx), Joint Research Centre of the European Commission, accessed 23 October 2023.
GET https://help.aranet.com/aranet-radiation-sensor/aranet-radiation-sensor/quick-start-guide.md?ask=<question>&goal=<user_goal>
