Activating License via Activation Code
This is related to workspaces, which have Trial/Management licenses. Or freshly created workspaces.
Any Trial/Management license workspace is able to upgrade its license. The activation code allows for managing this in a much easier and faster way than before.
Customer can purchase a Cloud license only or a device bundle (base + sensors) with a cloud license on aranet.com
To proceed, you have to log in to your aranet.com account profile. After you have logged in, please head to the Shop -> Aranet Cloud, and click on the Aranet Cloud license. The following screen will appear:
Here you can choose the type of Cloud License - Basic or Annual, the number of base stations, and the sensors.
Then add it to the cart, and finish the purchase. After finishing the purchase, an email with a unique code will be sent, and it will appear in the tab My Cloud Licenses. From now, you will have 6 months to activate your Cloud License.
Cloud service usage begins only when the code is activated in the Aranet Cloud workspace.
Now, to activate your license and redeem the code, head to your Aranet Cloud workspace.
After you have logged in successfully, head to the Base Stations tab and click on Add Base Station. As soon as this is finished, you will be able to activete a Basic/Pro license for your workspace.
You can redeem it from different tabs in Aranet Cloud, like:
From Workspace -> License -> Redeem code:
From the Create new workspace pop-up window:
Or from any other tab, by pressing the Upgrade license button, which is coloured in orange.
Redeeming the code
After you have pressed Redeem code, a new pop-up window will appear:
Here, you have to enter the code that you have received.
After you enter your code, please click on the Apply button. A new screen will appear, which acknowledges a successful upgrade.
To check the status of the licence, please head to Workspace -> License. Here you will see all necessary information regarding your license, such as: Which license package are you using, how many base stations and sensors it includes, and until which date the license is valid.
Error handling
In some cases, it is possible to get the error messages, which do not allow for upgrading the plan.
Activation code is invalid - this message states that there is no such code that can be synchronized with the database and activated.
Please check whether the code is entered correctly and matches the expected format. Format example: A1B2-C3D4.
Activation code has expired - the following message states that the code has expired. This means that the code was not activated for a period of 6 months after the purchase was made.
Activation code already used - this message states that the code was previously used to upgrade another workspace and can not be used multiple times.
Activation code is deactivated - if you get this message, please get in touch with support.
