> For the complete documentation index, see [llms.txt](https://help.aranet.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://help.aranet.com/aranet-cloud-page/aranet-cloud-landing-page/user-interface-and-core-features/sensors/disabling-sensor.md).
# Disabling Sensor
**The following information is valid only for physical sensors. Virtual sensor deletion is described in another topic.**
**DISABLE SENSOR** button in Sensor **CONFIG** tab is active when:
1. Sensor is not included in enabled and active Integration;
2. Sensor is not included in enabled and active Rule.
<div data-with-frame="true"><figure><img src="https://2831658296-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FRKwQxnS51pLI9fOl4xXp%2Fuploads%2F4HmgalyPsXkBrBTWyGtn%2Fimage.png?alt=media&amp;token=ead7e1fa-1517-4feb-b97f-b45cfb992193" alt=""><figcaption></figcaption></figure></div>
Pressing this button will disable the sensor from the cloud logically. This means:
* This sensor will not be found in any filters
* This sensor's **Tags** will be cleared
* No **Alarms** will be created for this sensor
* No history measurement data is deleted
**Please note**: the logical sensor's disabling does not impact aranet.cloud sensors number license. Sensor's data will continue to be registered in the cloud. To completely delete the sensor from the license and stop registering its data, you must unpair the sensor from Aranet Pro base.&#x20;
When a sensor is logically disabled, it appears in the **Disabled sensors** tab of the **SETTINGS** menu. You can restore a disabled sensor anytime: open the sensor's card and click the **RESTORE SENSOR** button in the **CONFIG** tab. You will need to add **Tags** to the sensor and include it in **Rules** again.
<div data-with-frame="true"><figure><img src="https://2831658296-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FRKwQxnS51pLI9fOl4xXp%2Fuploads%2FkAM1ugnJz0TstsS21vbL%2Fimage.png?alt=media&amp;token=f540c637-ce8b-42e4-a837-f41aad170161" alt=""><figcaption></figcaption></figure></div>
GET https://help.aranet.com/aranet-cloud-page/aranet-cloud-landing-page/user-interface-and-core-features/sensors/disabling-sensor.md?ask=<question>&goal=<user_goal>
