> For the complete documentation index, see [llms.txt](https://help.aranet.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://help.aranet.com/aranet-cloud-page/aranet-cloud-landing-page/integrations-and-extensions/cloud-api/create-cloud-api-key.md). Agents can also search and read this documentation through its [MCP server](https://help.aranet.com/~gitbook/mcp).
# Create Cloud API Key
#### Who can manage the integration?
{% hint style="info" %}
* Workspace owners
* Workspace administrators
* Or users who have Write permission for Integrations.
{% stepper %}
{% step %}
### Access your account
Log in to your Aranet Cloud account, but before you proceed with creation, make sure that the permission requirements are met.
<div data-with-frame="true"><figure><img src="https://2831658296-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FRKwQxnS51pLI9fOl4xXp%2Fuploads%2FrtbXQ7iMCRPYw9NPAMXk%2Fimage.png?alt=media&amp;token=50ac772b-9eb6-4287-8839-74c1e8245e06" alt=""><figcaption></figcaption></figure></div>
{% endstep %}
{% step %}
### Locate the API tab
Navigate to the **SETTINGS** menu and select the **API** tab:
A brief API key description and [link to complete Aranet Cloud API documentation](https://test.aranet.cloud/openapi/)[ ](https://aranet.cloud/openapi/), as well as the list of created keys, are here.
<div data-with-frame="true"><figure><img src="https://2831658296-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FRKwQxnS51pLI9fOl4xXp%2Fuploads%2FOQDFENxYqRgFxEGRHb5Y%2Fimage.png?alt=media&amp;token=6b9e8947-b6da-44f6-bbb4-c67e9bd0f01d" alt=""><figcaption></figcaption></figure></div>
{% endstep %}
{% step %}
### Create API key
Click on the **CREATE NEW** button; a new pop-up window will open:
<div data-with-frame="true"><figure><img src="https://2831658296-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FRKwQxnS51pLI9fOl4xXp%2Fuploads%2FCYGgdKs5etDFCg7zCkTu%2Fimage.png?alt=media&amp;token=b48b6ea5-9e5c-435e-b996-e7bff4fdd4d6" alt=""><figcaption></figcaption></figure></div>
Enter the API account name, descriptio&#x6E;**,** and key expiration date (if needed)**.** Press **the CREATE** button.
<div data-with-frame="true"><figure><img src="https://2831658296-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FRKwQxnS51pLI9fOl4xXp%2Fuploads%2F5dUzzc0NZatYepxhglUc%2Fimage.png?alt=media&amp;token=5ba0c96d-277b-4dc5-a9d2-b22c81375b47" alt=""><figcaption></figcaption></figure></div>
API key expiration, by default, is set to: Never
After you click the CREATE button, the API key will be created.
To see your generated API key, you have to click on the API you created, or on the pencil icon, where a new pop-up window will appear:
<div data-with-frame="true"><figure><img src="https://2831658296-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FRKwQxnS51pLI9fOl4xXp%2Fuploads%2FlvwdjgliU6mlMnCVVoPO%2Fimage.png?alt=media&amp;token=dae1492c-19d9-405c-af64-0d43f60790bc" alt=""><figcaption></figcaption></figure></div>
You will see the generated API key, which can be copied to the clipboard by pressing the button. API key expiration date can be adjusted; then the key can be **SAVED** or **DELETED**. If no changes are needed, close the window.
{% endstep %}
{% endstepper %}
#### Locate your API integration
The updated API tab with the new key in the list opens:\
You can review the API key log file by pressing the *clock* button, or edit it by clicking on the *pencil* button.
<div data-with-frame="true"><figure><img src="https://2831658296-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FRKwQxnS51pLI9fOl4xXp%2Fuploads%2FZGZOM4khoisedIf3zCfT%2Fimage.png?alt=media&amp;token=51309b92-3780-4fe8-91e9-bdbe272e005a" alt=""><figcaption></figcaption></figure></div>
<div data-with-frame="true"><figure><img src="https://2831658296-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FRKwQxnS51pLI9fOl4xXp%2Fuploads%2FIvdoso7rQpi0iKH5UFHM%2Fimage.png?alt=media&amp;token=59b1239d-4135-42ce-b35d-d62f63ace5fa" alt=""><figcaption></figcaption></figure></div>
GET https://help.aranet.com/aranet-cloud-page/aranet-cloud-landing-page/integrations-and-extensions/cloud-api/create-cloud-api-key.md?ask=<question>&goal=<user_goal>
