> For the complete documentation index, see [llms.txt](https://help.aranet.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://help.aranet.com/aranet-cloud-page/aranet-cloud-landing-page/gateway-pro-management/firmware-update.md).
# Firmware Update
To update your Gateway Pro from Cloud, you need to have:
* Cloud version 2.0 or newer
* Gateway Pro connected to the Cloud
* User with write permission to base station management
If all of these are fulfilled, then you can head to the Base stations tab, and you will see a screen like this:
<div data-with-frame="true"><figure><img src="/files/j4vtTf6ihGA1aNurvnbh" alt=""><figcaption></figcaption></figure></div>
A yellow turning cog icon will be visible if a new firmware version is available. To start the update, click on the MANAGE button, and a new screen will pop up:
<div data-with-frame="true"><figure><img src="/files/M6CtgrrOlnGIRN9F8zyH" alt=""><figcaption></figcaption></figure></div>
In this window, you can see that a New Firmware version is available. You need to press New Firmware button to proceed with the upgrade of the gateways' firmware. After pressing the button, you will see a pop-up window:
<div data-with-frame="true"><figure><img src="/files/gAGGDZeDtMgfd2LWHuU8" alt=""><figcaption></figcaption></figure></div>
Here, you need to confirm your action to get the Upgrade button active. After clicking on the Upgrade button, the base station and Cloud will start to establish a connection:
<div data-with-frame="true"><figure><img src="/files/sxPdsJ2wNzT7qMO2suSk" alt=""><figcaption></figcaption></figure></div>
This connection establishment can take up to 2 minutes, and the update itself can take up to 15 minutes, so be patient. After a connection has been established, the base will start updating and rebooting, and you will lose connection to the base.
<div data-with-frame="true"><figure><img src="/files/CLKRHX0MJhK1ZYOhXTi3" alt=""><figcaption></figcaption></figure></div>
<div data-with-frame="true"><figure><img src="/files/9g1OYwT8KY5t03jNsOXc" alt=""><figcaption></figcaption></figure></div>
After a successful upgrade, a green checkmark will appear, and the firmware version will be updated to the latest one. If the upgrade fails, then a red checkmark next to the firmware number and an "Upgrade has failed" will show up.
GET https://help.aranet.com/aranet-cloud-page/aranet-cloud-landing-page/gateway-pro-management/firmware-update.md?ask=<question>&goal=<endgoal>
