Connect Gateway Pro
Aranet Gateway Pro can be connected to Aranet Cloud by registering it to the Workspace. The Aranet Cloud Workspace creation process is described in this topic: Create Workspace
If you just created a new Workspace, go to Base stations and press ADD BASE STATION button:
Registering Aranet Gateway Pro base to the existing WORKSPACE
  1. Log in with your credentials to Aranet Cloud and select WORKSPACE to which you wish to add a new Aranet Pro base (you should have Administrator or Owner rights).
  2. Navigate to the Base stations tab.
  3. Click on the NEW BASE STATION button.
  1. Choose device type "Aranet Gateway".
Then a new screen will pop up.
Here, you have to enter a 6-digit code, which is found on the screen of the Gateway Pro.
Please note that Gateway Pro should be connected to the Wi-Fi or Ethernet and have access to the internet for successful connection to Aranet Cloud (Connect to Network). When you have established an internet connection, go to the home screen (or stay in the configuration wizard) and press on Aranet Cloud (or on Connect to Aranet Cloud in wizard) to proceed with the connection.
Or
Then you need to wait until the 6-digit code shows up. It will look like this.
Now, enter the received code in Aranet Cloud, and press ADD to connect your Gateway Pro to Cloud.
After pressing ADD, and adding Gateway Pro, you will see the status "Waiting for base station...", this means that Aranet Cloud is trying to connect to Gateway Pro. This may take up to 1 hour. During this process, sensor data will gradually appear in the Aranet Cloud workspace.
When you have successfully connected to Aranet Cloud, you will see a status "Up to date". This means that your Gateway Pro has the latest Firmware and is Online:
On the display of Aranet Gateway Pro, you will get a message for successful connection, an icon will turn green on the Home Screen, and the status will show up as Connected:
