> For the complete documentation index, see [llms.txt](https://help.aranet.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://help.aranet.com/aranet-cloud-page/aranet-cloud-landing-page/base-management/firmware-update.md).
# Firmware Update
To update your base station from Cloud, you first have to have:
* Base station firmware version 4.5.0 or newer
* Cloud version 2.0 or newer
* Base station connected to the Cloud
* User with write permission to base station management
If all of these are fulfilled, then you can head to the base stations tab, and you will see a screen like this:
<div data-with-frame="true"><figure><img src="https://2831658296-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FRKwQxnS51pLI9fOl4xXp%2Fuploads%2FpwQK45JoCTVz5nYt05WW%2Fimage.png?alt=media&amp;token=02c43c0a-447d-470d-9c6d-71c2f7e2ad6e" alt=""><figcaption></figcaption></figure></div>
A yellow turning cog icon will be visible if a new firmware version is available. To start the update, click on the MANAGE button, and a new screen will pop up:
<div data-with-frame="true"><figure><img src="https://2831658296-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FRKwQxnS51pLI9fOl4xXp%2Fuploads%2F3pi6qhCXh6q8VYfMOCES%2Fimage.png?alt=media&amp;token=354e42e8-e656-4f29-b3ff-a9d25d86fbfe" alt=""><figcaption></figcaption></figure></div>
In this window, you can see that a New Firmware version is available. You need to press New Firmware button to proceed with the upgrade of the base stations' firmware. After pressing the button, you will see a pop-up window:
<div data-with-frame="true"><figure><img src="https://2831658296-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FRKwQxnS51pLI9fOl4xXp%2Fuploads%2FRXAEOiPNrT2sJcZTsQTs%2Fimage.png?alt=media&amp;token=5dbf7a54-12a2-4cda-ae05-07499d550270" alt=""><figcaption></figcaption></figure></div>
Here, you need to confirm your action to get the Upgrade button active. After clicking on the Upgrade button, the base station and Cloud will start to establish a connection:
<div data-with-frame="true"><figure><img src="https://2831658296-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FRKwQxnS51pLI9fOl4xXp%2Fuploads%2FIVblrrTqlZAXYlacL9vi%2Fimage.png?alt=media&amp;token=f030b437-0496-412f-8910-de6d8527171c" alt=""><figcaption></figcaption></figure></div>
This connection establishment can take up to 2 minutes, and the update itself can take up to 15 minutes, so be patient. After a connection has been established, the base will start updating and rebooting, and you will lose connection to the base.
<div data-with-frame="true"><figure><img src="https://2831658296-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FRKwQxnS51pLI9fOl4xXp%2Fuploads%2F6HiCAGWhQ69JbHcNaOva%2Fimage.png?alt=media&amp;token=0fb69e31-041c-4014-a13b-f65a89997dd4" alt=""><figcaption></figcaption></figure></div>
<div data-with-frame="true"><figure><img src="https://2831658296-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FRKwQxnS51pLI9fOl4xXp%2Fuploads%2FKtRfI4TDb7ZxP7POHuVe%2Fimage.png?alt=media&amp;token=8f2a3535-fed6-468a-8eb9-04aae13a2bca" alt=""><figcaption></figcaption></figure></div>
<div data-with-frame="true"><figure><img src="https://2831658296-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FRKwQxnS51pLI9fOl4xXp%2Fuploads%2FtWHaNAaQcMgUhGvI0Zy0%2Fimage.png?alt=media&amp;token=e5644d58-d89a-4fef-bc73-df500c03b2a3" alt=""><figcaption></figcaption></figure></div>
After a successful upgrade, a green checkmark will appear, and the firmware version will be updated to the latest one. If the upgrade fails, then a red checkmark next to the firmware number and an "Upgrade has failed" will show up.
GET https://help.aranet.com/aranet-cloud-page/aranet-cloud-landing-page/base-management/firmware-update.md?ask=<question>&goal=<user_goal>
