> For the complete documentation index, see [llms.txt](https://help.aranet.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://help.aranet.com/aranet-cloud-page/aranet-cloud-landing-page/base-management/connection-issues.md).
# Connection Issues
If you encounter a connection issue or have forgotten any credentials you changed to connect to the base stations' Access Point, you can reboot your base station, or reset network settings and use credentials from the base station sticker, which are located on the base station.
#### Aranet Pro Base Station
Disconnect the power cord and Ethernet cable (if connected) from the Aranet Pro base station.
Do a physical base restart with the small jumper switch next to the AC power port on the Aranet Pro base station body. Change the position of the jumper switch to the left, wait till 12V green LED turns dark, then change the position of the switch back to the right and 12V green indication should return:
<div data-with-frame="true"><figure><img src="https://2831658296-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FRKwQxnS51pLI9fOl4xXp%2Fuploads%2FlkuzIfz1fY2vA4DHF4z5%2FBase%20troble_2.png?alt=media&amp;token=9ff3b9c2-feca-4063-8f86-3b27aec307e0" alt="" width="563"><figcaption></figcaption></figure></div>
You can also reboot the device by rebooting it using WebGUI. To do so, head to System -> Tools tab, and press on Reboot:
<div data-with-frame="true"><figure><img src="https://2831658296-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FRKwQxnS51pLI9fOl4xXp%2Fuploads%2F0iQagWe1WqNkDFkkfmzA%2Fimage.png?alt=media&amp;token=c1b37320-369d-42f0-992b-d4d434c55865" alt=""><figcaption></figcaption></figure></div>
After pressing Reboot button, following message and pop-up window will appear, type in password of the base station and press "OK", after pressing, reboot will be initiated and your device will reboot:
<div data-with-frame="true"><figure><img src="https://2831658296-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FRKwQxnS51pLI9fOl4xXp%2Fuploads%2F5U6zmnkCVLP5G7gCdl6h%2Fimage.png?alt=media&amp;token=2a2d85e4-67bc-4c7c-a28d-fd32c0bdb09b" alt=""><figcaption></figcaption></figure></div>
If the problem persists try resetting network settings for the Aranet Pro base again physically with some thin and long object pressing and holding for at least 5 seconds reset button on Pro base body, but don't turn off the device. When a reset is happening, then the LEDs of the Aranet Pro base station should flash:
<div data-with-frame="true"><figure><img src="https://2831658296-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FRKwQxnS51pLI9fOl4xXp%2Fuploads%2FMeoqC2qdGB19eMehTf3s%2FBase%20troble.png?alt=media&amp;token=83018f80-04d9-4e79-a3ce-b6629dd2649a" alt="" width="563"><figcaption></figcaption></figure></div>
If the reset has succeeded, then the WiFi access point with the name ***“Aranet-\*\*\*\*\*\*” (***&#x63;reated by the base station) should be visible on all devices that can be connected to WiFi (phones, tablets, laptops, etc).
<div data-with-frame="true"><figure><img src="https://2831658296-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FRKwQxnS51pLI9fOl4xXp%2Fuploads%2FGp0TpKK5k15aSeZdkNbi%2FLabel.png?alt=media&amp;token=34223117-eb9d-45d3-bf10-e00866e69a1b" alt="" width="361"><figcaption></figcaption></figure></div>
Even if after the physical restart and reset of network settings, the WiFI access point created by Pro base is not visible on any Wi-Fi-capable devices, then most probably there is some hardware fault in the device, and it should be returned for repair, filling the RMA form: [RMA form](https://rma.aranet.com)
#### Aranet Pro Plus Base Station
Disconnect the power cord (RJ-45) from the Aranet Pro Plus base station.
<div data-with-frame="true"><figure><img src="https://2831658296-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FRKwQxnS51pLI9fOl4xXp%2Fuploads%2F4pshTAKmYXWWI3rCCB7U%2FBase%20disc.png?alt=media&amp;token=9be95cc1-c004-4854-9193-be76e0ee143f" alt="" width="375"><figcaption></figcaption></figure></div>
The base station will turn off after approximately 40 seconds. All LED lights should be turned off. Then plug the power cord back into the base station. Now wait until the LED of Wi-Fi appears, then try to connect to the base station's Access Point once again.
If the problem persists, try resetting network settings for the Aranet Pro Plus base physically by taking off the transparent lid, pressing the restart button. Hold the button for at least 5 seconds to perform a successful network reset. The device should remain turned on. When a reset is happening, then the LEDs of the Aranet Pro base station should flash:
<div data-with-frame="true"><figure><img src="https://2831658296-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FRKwQxnS51pLI9fOl4xXp%2Fuploads%2F05QqkBIUXspIWzz28ID2%2FVisual_2.png?alt=media&amp;token=780edac6-8496-4da0-95dc-599f195d2dc5" alt="" width="375"><figcaption></figcaption></figure></div>
Even if after the physical restart and reset of network settings, the WiFI access point created by Pro Plus base is not visible on any Wi-Fi-capable devices, then most probably there is some hardware fault in the device, and it should be returned for repair, filling the RMA form: [RMA form](https://rma.aranet.com)
GET https://help.aranet.com/aranet-cloud-page/aranet-cloud-landing-page/base-management/connection-issues.md?ask=<question>&goal=<user_goal>
