> For the complete documentation index, see [llms.txt](https://help.aranet.com/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://help.aranet.com/aranet-cloud-page/aranet-cloud-landing-page/base-management.md).
# Base Management
With Aranet Cloud update 2.0.26 and base station Firmware update v 4.13 a new base management feature has been added: Sensor management. To access this feature the user should have "Write" permission to access this. License management is also available.\
With base station FW v4.9.9 you also have access to base station reboot and downloading of the diagnostic data.\
Go to Base stations and you should see a screen similar to this.
<div data-with-frame="true"><figure><img src="https://2831658296-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FRKwQxnS51pLI9fOl4xXp%2Fuploads%2FwmOVu6k3KSZ41ecdqmKJ%2Fimage.png?alt=media&amp;token=34314801-8823-4ed5-b0be-d06995d43974" alt=""><figcaption></figcaption></figure></div>
#### "MANAGE" functions
By pressing the MANAGE button a new pop-up screen will show up.
<div data-with-frame="true"><figure><img src="https://2831658296-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FRKwQxnS51pLI9fOl4xXp%2Fuploads%2FTdlGZU1txcArPpfXZjfV%2Fimage.png?alt=media&amp;token=0f2ed292-b13e-4388-aa8d-98553c3abbfd" alt=""><figcaption></figcaption></figure></div>
The following screen contains 6 buttons and&#x20;
**1. Shows the name of your base station.**\
**2. Status of the connection to the base station from Cloud**. By default it is inactive (Ready to connect) and when you click on any of the following buttons, it initializes a connection. This initialization can take up to 90 seconds.
<div data-with-frame="true"><figure><img src="https://2831658296-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FRKwQxnS51pLI9fOl4xXp%2Fuploads%2Fb5aQV4aRbUdudiqQlCQo%2Fimage.png?alt=media&amp;token=134980dc-5b11-4f3c-a865-42a34c6a4638" alt=""><figcaption></figcaption></figure></div>
**3.** **Manage & Pair sensors**. Here you are available to manage sensors and even pair them to a base station.&#x20;
**4.  Integration configuration** - Not available yet
**5. License management**. The license management function shows the information about the licenses on the base station, including each license state and expiration date. Any new purchased license is available to upload to base station directly from Cloud user interface – no more license file copying onsite.
**6. Device settings.** Allows you to cahnge your base station's name, set up date, time, language and measurement units.
<div data-with-frame="true"><figure><img src="https://2831658296-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FRKwQxnS51pLI9fOl4xXp%2Fuploads%2F7lubQ3kuZYeTpg3MuxbU%2Fimage.png?alt=media&amp;token=2f8be1e7-566a-4a9f-bb00-39145b8aa8d4" alt="" width="563"><figcaption></figcaption></figure></div>
<div data-with-frame="true"><figure><img src="https://2831658296-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FRKwQxnS51pLI9fOl4xXp%2Fuploads%2FRE6LlPLzUgJKvncZWTAL%2Fimage.png?alt=media&amp;token=45848f85-abfc-4c4b-a581-0332347b1fa2" alt="" width="563"><figcaption></figcaption></figure></div>
**7. Base firmware update**. More info here: [Firmware Update](/aranet-cloud-page/aranet-cloud-landing-page/base-management/firmware-update.md)
**8. Remote reboot** - You can trigger a reboot of the base station from here.
**And diagnostic file from the base station** - If support asks to download the diagnostic file, then if the base station is online, this can be done from here.
#### **Sensor pairing and management**
When you have established a connection and entered the sensor management page you should see this page:
<div data-with-frame="true"><figure><img src="https://2831658296-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FRKwQxnS51pLI9fOl4xXp%2Fuploads%2FtKxKR4vWnKIeIckhwT84%2Fimage.png?alt=media&amp;token=7576d849-50a8-4ada-8e72-99ad0121035f" alt="" width="563"><figcaption></figcaption></figure></div>
As in the base station GUI, here too, you can pair and manage the sensors in the same way.
**1. Measurement interval.** Select the measurement interval you want.
**2. Pair sensor button.** Starts the pairing process
**3. Search bar.** You can search by name and sensor ID.
**4. Sensors.** Here you can see some info about the sensors, such as the name, ID, picture, and pairing time.
**5. Edit button.** Clicking this will allow you to edit the sensor settings.
#### Sensor pairing process
To pair a new sensor or re-pair a sensor with a new measurement interval you should press the "Pair sensor" button and a new window will appear:
<div data-with-frame="true"><figure><img src="https://2831658296-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FRKwQxnS51pLI9fOl4xXp%2Fuploads%2FJsCkUXLZnZirylu5hzYb%2Fimage.png?alt=media&amp;token=da9cfefa-dad2-4be0-9d68-200fbbda0335" alt=""><figcaption></figcaption></figure></div>
After you click "start" this screen will be shown.
<div data-with-frame="true"><figure><img src="https://2831658296-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FRKwQxnS51pLI9fOl4xXp%2Fuploads%2FsXSYPddQkMz1dV0g3aHp%2Fimage.png?alt=media&amp;token=9aa1d415-ab17-4dd2-877c-b00941ab81e7" alt=""><figcaption></figcaption></figure></div>
The warning shows how to pair the sensors; the same basic principles that apply to pairing with the base station as here.\
1\. Make sure you are within 20 meters of the base station.\
2\. Remove the batteries for \~20 seconds, then add them back in, or press the pair button on the sensor.\
3\. You have 2 minutes to pair a sensor this way.
Through the Aranet Cloud, only single-sensor pairing is possible. After the pairing, the session will end and you will have to press the pair button again to pair another sensor.
#### Sensor management
When you've clicked to edit a sensor, this screen will open:
<div data-with-frame="true"><figure><img src="https://2831658296-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FRKwQxnS51pLI9fOl4xXp%2Fuploads%2FCxhy4Jp3DcmNekYFoqpF%2Fimage.png?alt=media&amp;token=831d44c4-6d21-4794-a907-7dfe202787d1" alt=""><figcaption></figcaption></figure></div>
From here you can change the measurement interval, and name and even add a conversion.
For more advanced sensor management take a look at these pages:
[Pulse Counter (Energy meter) management](/aranet-cloud-page/aranet-cloud-landing-page/user-interface-and-core-features/sensors/sensor-management-using-cloud.md)
[WET150 VWC management](/aranet-cloud-page/aranet-cloud-landing-page/user-interface-and-core-features/sensors/sensor-management-using-cloud.md)
[4-20mA, 0-10 V sensor management](/aranet-cloud-page/aranet-cloud-landing-page/user-interface-and-core-features/sensors/sensor-management-using-cloud.md)
For the weight sensor another button appears, the Tare button allows you to Tare the weight that is on the sensor.
<div data-with-frame="true"><figure><img src="https://2831658296-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FRKwQxnS51pLI9fOl4xXp%2Fuploads%2FiHGz6e0yTyGo49GY8BPf%2Fimage.png?alt=media&amp;token=7add6dbd-4b58-46af-8d44-65563981ce36" alt=""><figcaption></figcaption></figure></div>
#### **License management**
This screen will greet you when you open the license management screen. A list of "Ready for upload" and "Uploaded" licenses will be available as well as a "Sync" button that will sync and sanitize unavailable licenses on the base station.
<div data-with-frame="true"><figure><img src="https://2831658296-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FRKwQxnS51pLI9fOl4xXp%2Fuploads%2F4SYLpNdGoi7SiBAYktdB%2Fimage.png?alt=media&amp;token=7de50188-5d4f-45c6-accd-b4f2579bc14f" alt=""><figcaption></figcaption></figure></div>
GET https://help.aranet.com/aranet-cloud-page/aranet-cloud-landing-page/base-management.md?ask=<question>&goal=<user_goal>
